Forums59
Topics128,332
Posts1,054,206
Members46,615
Most Online1,229 Jan 21st, 2020
OP
I have an android computer and this AD is for a permanent ad remover program but I can't get rid of the ad remover Ad. HELP. It only shows up when I go to YOUTUBE.
Insomniac
You don't say which browser you are using. I think you should use Brave. It's default set up is to block ads. https://brave.com/tag/android/
Gord ---- 1954 1/2 ton 235 4 speed
OP
Ex Hall Monitor
I use Ad Block Plus as an extension in Firefox. I just went to youtube in another tab and it showed it was blocking three ads on that page. No ads were displayed on the page. I've seen it showing as many as 25 ads blocked on a single page.
Insomniac
I was watching this YouTube video on rebuilding GM 10 bolt rear end: www.youtube.com/watch?v=sjQcog-GU9I [ youtube.com] Brave reported 526 trackers, ads and more blocked!
back yard wrench turner
Hemmings News has just installed a program that blocks their pages when I am using an adblocker. They demand it gets turned off.
I'm not happy and have told them so.
Wayne When I die, I hope she doesn't sell everything for what I told her I paid for it! 1938 1-Ton Farm Truck-30- Stovebolt Gallery Forums
Just a heads up:
If you want to get rid of YT ads, use YouPipe instead. You find it on F-Droid (you have to install F-Droid before).
You can also just listen to the audio (with the screen turned off), and download any video (or just audio).
Frank
OP
I am trying to get rid of an AD for a blocker and they want $29.00 for the blocker. It only comes up on Youtube. This is the ad. [ secure.totaladblock.com]. It comes up in the upper right corner.
There's a simple, very effective method of not having to see that ad- - - - -just don't try to play you tube videos. The other approach would be to clear out your browser history and get rid of the cookie that's triggering the ad. Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
OP
I was wrong it is popping up on other sites. I will try some of your suggestions Jerry.
