The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
2023 ... plans, plans, plans
Holidays are over
Hunkering down for winter ... how about your truck?
Winter storage.
Doing some truck maintenance?
The Shops Area may be useful.
Eager to plans some trips?
See what's shaking near you in The Side Lot.
How about your computer?
Plenty of help in the IT Shortbus.
Be of good cheer!
The days are getting longer.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
17 members (Atticusnine, Frank50, glennj3, 5 invisible), 176 guests, and 3 robots.
Forums59
Topics128,267
Posts1,053,232
Members46,580
Most Online1,229
Jan 21st, 2020
#1476266 Wed Nov 23 2022 01:41 AM
Lugnutz Offline OP
Several years ago I installed aftermarket glue on factory style door seals in my 1965 C10. I was not impressed. The door was very hard to close. After the seals were in for a few months, the doors were less difficult to close, but still very tight.
In 2014, I read a post on another forum. The writer had discovered that 2006 through 2009 Honda Civic 2 door coupe door seals were a PERFECT fit for a 1964–1966 C10 cab. The Honda seals are a press on fit and do not require any glue. The best part about it was that you didn’t have to slam the door anymore.
I just installed a pair of 2010 Honda Accord two door coupe door seals on my 1963 C10. I am very pleased with the fit and how the door closes without slamming. (I still need to adjust my driver door a bit to get it to close better.)
I’ve tried to find other press on door seals at the salvage yard. Chevy blazer door seals look like they should fit well, but they are a little bit too tight.
I’ve already tried the glue on style seals sold by vendors and was not impressed. Door seals are made by companies like Precision and Steele Rubber. I cannot say if those seals fit well or not because I have not tried them. However, I am very pleased with my investment of $16 for a pair of salvage yard 2010 Honda Accord coupe door seals.
VIDEO LINK [youtu.be]
LINK to the forum thread that started it all. [67-72chevytrucks.com]
Lugnutz #1476295 Wed Nov 23 2022 12:12 PM
Are these new or out of a salvage yard?
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
Ferris Bueller #1476302 Wed Nov 23 2022 01:05 PM
Lugnutz Offline OP
The seals you see in my video were from a salvage yard. I paid $16 for the pair plus I had a spare piece to splice the 4” additional needed on each side (60-63 only). The seals are a perfect size for 1964-66 doors.
Moderated by  Hambone
