The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Whatcha doing now?
What did you get done on your Bolt today? - 2021 and later
The original thread is still in tact and we have 14 pages already for this time frame. A "mini-Project Journal" if you will.
Stovebolt driving report
Started by Cletis in 2012 - 36 pages and going strong!
Who uses their truck as a truck - 2021 and later
Re-started this thread. Three pages and counting.
Bolters in the Side Lot
are planning get togethers and what not. See who's near you.
Stay busy; keep warm!
Share your enthusiam.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
3 members (Jethro in Va, DaveV, Steve L.), 66 guests, and 3 robots.
Forums59
Topics128,332
Posts1,054,207
Members46,615
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1476091 Mon Nov 21 2022 02:13 PM
I am a big fan of the vinegar method. I have soaked many parts including build a trough and soaking a bumper. This might be an obvious question but will vinegar also remove paint. I have a vintage license plate I plan on placing on my latest project. It is okay but has some rough spots. I thought if I could just remove the rust and them clear coat I would be okay with the condition. No other restoration needed. I was just wondering if I soaked it in vinegar if it would also removed the paint?
Dave from Northern Kentucky
My 54 3100
dgrinnan #1476104 Mon Nov 21 2022 05:19 PM
Curmudgeon
That is a nice original plate. I can see why you want to preserve what remains. If you strip it all off and repaint then it's not original anymore. Since I'm not a plate restorer, the best I can do is provide information.
Vinegar is an acid and has a pH of 2 to 3. The pH of water is 7. The higher the pH the weaker the acid. Evaporust pH is 6.1. All acids can discolor and/or remove paint depending on how long it is in contact with the acid. I have read you use baking soda to quickly neutralize the acid. Evaporust may be better as far as less reaction with paint but be warned that Evaporust is slow at removing rust. Regardless of which acid you use, paint may come off if there is rust underneath the paint.
Once bare metal (steel) is exposed it will slowly begin rusting from moisture in the air. If you rinse the bare metal with water, you have to dry it off immediately or it will quickly rust.
Clear coating bare steel can be a problem. It also should not react with the existing paint. Try to avoid knee-jerk comments and advice here. Some clear coats are UV sensitive, some turn yellow with age and some might crack or peel over time. You don't want to apply anything that might reduce the life of the original finish. You may want to investigate something that provides protection (water, dirt, sunlight etc.) but can easily be removed. It may require periodic re-application similar to wax.
Keep us posted. This is an interesting subject
dgrinnan #1476123 Mon Nov 21 2022 09:42 PM
Once you remove the rust, what are you going to put on the metal?
Personally, I'd remove what comes off easily with steel wool or a small wire brush in a Dremel tool and then leave it alone. Taking the rusted area to bare metal will require painting which won't match the original paint.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
dgrinnan #1476127 Mon Nov 21 2022 10:11 PM
I'd be careful with Evaporust. I used it to derust an old Craftsman 1/4" socket set box and it removed the paint. That being said, the paint on old license plates may be baked on and a little more durable than the box I derusted.
As long as you remove the oxygen from the metal, I think you could clear coat it and keep it from continuing to rust. Is there an epoxy clear coat that would withstand UV? - Don't know. I have used a POR15 product called Glisten PC that I put on a set of aluminum wheels, and it seems to be holding up fine. I think it's now Clear 2K Urethane but for a single license plate? $$$$$$ big_eek
I'm no expert, just throwing ideas out there. I think I'd clear coat it as-is. Looks good now.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
dgrinnan #1476131 Mon Nov 21 2022 10:27 PM
Curmudgeon
Kevin, if it was like my old shiny slick Craftsman set, I could scratch paint off with my fingernail. If it was doused in muratic acid, it would remove the paint and leave pit holes where it attacked the metal.
I think Dave needs to talk with people who do preservation. Maybe old metal Children's toys where you lose value if you remove the old finish and repaint.
buoymaker #1476134 Mon Nov 21 2022 10:38 PM
This was a '40s Craftsman set and the paint that was still on it was stuck pretty well. Must have had some rust underneath the edges that let the evaporust get under the paint. I don't remember how long I soaked it, but it was at least overnight.
dgrinnan #1476142 Mon Nov 21 2022 11:44 PM
I use citric acid ,you can mix it any strength ,it works like vinegar but I think it works faster.,I would try it on a small area to see how it effects the paint but I notice there will be a line we’re the liquid level and object is sticking out. ,I have two headlight buckets in soaking right now and will take a picture when I pull them out ,so far the paint is staying on.If your licence plate is not at risk of rusting through you may want to treat it like a patina vehicle we’re they coat it with i beleave lindseed oil .
dgrinnan #1476147 Tue Nov 22 2022 12:47 AM
I think etch n prep is what to use. It has phosphoric acid in it, it sort of removes rust but more so converts it. And any 2k clear top coat should not yellow unless too much is sprayed onto the part. 2K top coat clear is not UV sensitive.
dgrinnan #1476172 Tue Nov 22 2022 04:02 AM
Here is the buckets they were in for about a day and a half .I don’t think you would want to put your licence plate in unless you plan to repaint it complete.
dgrinnan #1476186 Tue Nov 22 2022 12:11 PM
Thanks everyone. After all the good feedback I might be better off gently removing any loose rust and just do something like the linseed oil. I don't want to ruin the look of the vintage plate.
My 54 3100
Page 1 of 2 1 2
