Forums59
Topics128,332
Posts1,054,207
Members46,615
Most Online1,229 Jan 21st, 2020
OP
I'm curious what you guys use and recommend in regards to what pressure of radiator cap you use on the original radiators in the AD trucks. My truck is a 53 half ton with the original radiator, and a 235 engine.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1953 Ford Victoria 1950 Studebaker Starlight Coupe
Original radiators and heaters are only built to use lower pressures, if modern higher pressures are used to raise the building point, older units will leak!
Ed
back yard wrench turner
My 38 is a non pressure system.
Wayne When I die, I hope she doesn't sell everything for what I told her I paid for it! 1938 1-Ton Farm Truck-30- Stovebolt Gallery Forums
If there is a housing that resembles a tuna can on the upper radiator tank with a vent tube attached to it, you have a "zero pressure" system that does not use a pressure cap. Later systems with the vent tube attached to the radiator fill neck can handle a little pressure, like maybe 4 pounds, or possibly 7 on vehicles from the late 1950's, but be aware that the heater core is probably the weak point. Too much pressure will cause the radiator core and/or the heater to spring a leak. Modern replacement radiators can handle up to 15 pounds or so, but the heater must be upgraded also. Each pound of pressure on a cooling system raises the boiling point of the coolant 3 degrees F. at sea level so a 7# cap will let the coolant reach 233 degrees before it boils. Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
My truck came to me with a 4 pound cap. I installed a coolant reservoir and it works perfectly filling up when hot and lowering to the cold line as it cools off. Radiator is filled to the very top.
1939 Packard Standard Eight Coupe (The Phantom) 1950 Chevrolet 3100 (Ol' Roy) 1956 Cadillac Coupe de Ville (The Bismarck) 1966 Oldsmobile Toronado (The Purple Knif) 1966 Ford Mustang (Little Red) 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 (Big Red) 1995 Ford F-150 (Newt)
AD Addict
I'm curious what you guys use and recommend in regards to what pressure of radiator cap you use on the original radiators in the AD trucks. My truck is a 53 half ton with the original radiator, and a 235 engine. I’m running a 4 lb. cap on my ‘59 235 in my ‘52 with the original radiator.
Insomniac
Hmmm. I have a 7 lb. cap. I have a new aluminum radiator, but the heater core is original. No leaks so far, but maybe I should buy a 4 lb. cap.
Gord ---- 1954 1/2 ton 235 4 speed
The only purpose of any pressure cap is to allow the coolant temp is to rise above the boiling point and stay liquid- - - -the same principle a pressure cooker uses. With a good coolant recovery system, anything that escapes past the pressure cap gets recycled back into the system when the engine cools down. That's probably a better idea than trying to keep all the liquid in the radiator all the time, and a lower pressure cap can be used to protect the heater core. Very few stovebolts with a clean, proper capacity radiator run 200+ degrees for very long if the water jacket is clean and the right temp thermostat is used. A 180 stat is probably the best choice to get the engine up to normal temp and still have a little cushion before the boiling point is reached. Engines that run cold all the time try to beat themselves to death with wide piston skirt and bearing clearances. Jerry
My last Stovebolt, a 1950 3600 with 216 had what may have been the original zero pressure cap. The shop manual calls for zero pressure for 1950, but not sure about others.
Professional Novice
The 48-51 Service manual says that all trucks except COE's use a no pressure radiator. It says the COE uses a 3.5-4.5 psi cap.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
