The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Whatcha doing now?
What did you get done on your Bolt today? - 2021 and later
The original thread is still in tact and we have 14 pages already for this time frame. A "mini-Project Journal" if you will.
Stovebolt driving report
Started by Cletis in 2012 - 36 pages and going strong!
Who uses their truck as a truck - 2021 and later
Re-started this thread. Three pages and counting.
Bolters in the Side Lot
are planning get togethers and what not. See who's near you.
Stay busy; keep warm!
Share your enthusiam.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
7 members (MT45, Rovertech, Darling, Chevrolet Canada, 48bigtrucks, Phak1, 1 invisible), 63 guests, and 3 robots.
Forums59
Topics128,332
Posts1,054,207
Members46,615
Most Online1,229
Jan 21st, 2020
Page 4 of 7 1 2 3 4 5 6 7
Originally Posted by 55shaker
It works OK. The blower is a bit noisy on the high speed. It wasn't too difficult to install either.
As if a 70 year old truck cabin is quiet anyway. I can't hear my heater on high when I'm on the freeway because its drowned out by wind noise and valve clatter!
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
DonBolt Offline OP
Hi guys. Thank you for the follow up.
I bought a recirculating heater from Ebay that will probably need restoring to work. (See photo). I'll probably get around to that after the holidays.
If the core is bad, I'll use Jon G's copper tubing core idea, maybe a new motor, lube and cosmetics.
Your photos and process looks great Mike. I'll pm you for restoration tips.
Don
DonBolt
1955.1 3100, 235, 12v, 5-window, 5 speed
You should be able to split the fan motor carefully and clean the inside and grease the bushings , just be careful of the Brushes as they are difficult to put in place when putting back together
DonBolt Offline OP
Any tips for pressure testing the old heater core?
Did someone say household water pressure is enough to emulate our low pressure cooling system?
(I have a 7lb pressure cap on my 235 w/new reproduction radiator.)
DonBolt
AD Addict
Household water pressure (typically 30-60 psig) is way too much to test a heater core. My ‘59 235 runs a 4 lb. cap so testing much above that is asking for trouble. I have tested filling the core with water, plugging one side and applying air pressure to the other. if you can get your air compressor regulator down to 8-10 PSIG, that is more than enough. You also may be able to borrow on from your FLAPS.
Phil
Moderator, The Engine Shop & Interiors
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Someone on here Used a bike pump I will try to find it on here.
Here are a few from this site .the first one is from brad Allen and the last pic is off y tube.
Auto Zone, Advance Auto, etc will loan you a radiator pressure testing kit for free.
1979 Ford F-100
DonBolt Offline OP
Thanks for the excellent pressure testing ideas.
My truck has no heater switch on the dash, and one didn't come with the Ebay heater.
Does the switch determine high or low fan speed?
Can I use a 15 amp toggle switch?
Don
DonBolt
A toggle switch will only give you one speed. On and Off.
If you want variable speed, get one of the rheostat switches. Or get one of the Hi Med Lo Off switches.
It's Standard Motor Products part# HS92 (6v) available from Classic Truck Parts and other places. It's available in 6v and 12v (HS572) and it's lighted as well.
1979 Ford F-100
Moderated by  ndkid275, Phak1
