I can't tell if the issues is tires, suspension or my driveline. I have been test driving my new 47 project truck after it has being off the road for over 20 years. It is now running good. Engine, clutch and 3 speed transmission all seem good. Here is what I need some help with. i am not sure what to check. While going down the road the truck seems to run fairly smooth. When I am either decelerating or just push the clutch in there is very noticeable high speed vibration. The second the clutch engages it stops unless I am braking with the engine. If that is the case I notice it but not as much as just coasting with the clutch in. My first thought was an out of balance wheel but the fact it seems tied to what is going on with the driveline has me baffled.
