The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 70 guests, and 3 robots.
Forums60
Topics127,652
Posts1,046,325
Members46,394
Most Online1,229
Jan 21st, 2020
#1469250 Sun Oct 02 2022 08:11 PM
ronsway Offline OP
I have a '41 AK that the clutch, driveshaft/torque tube and rear end were rebuilt last year. They had a real problem with the driveshaft and a bushing in the torque tube. Had to have the machine shop get involved. Something about a bushing getting pressed out and a new one made and installed.l
Everything worked fine for awhile and then I started getting a "ratcheting" noise from driveline when slowing down. The shops both said was just a "self clearing" issue . That has got much better. Now I have a vibration in driveshaft at 45 mph and above. Doesn't sound or feel like a U-joint. Only happens at speed and goes away when below 45.
The shop/mechanic who did the work is not longer available to ask. Any suggestions ? I have already thought about not going above 45, but I put the 355 gears in to be able to cruise at 55.
ronsway #1469254 Sun Oct 02 2022 08:24 PM
Get under the truck with the rear wheels raised and turn the driveshaft by hand and see if there is slop or slack in the U joint before the axle begins turning. Even a few thousandths of an inch of play can give you a vibration.
Try to move the shaft from side to side and see if the is any play at the U joint / yoke.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
ronsway #1469426 Mon Oct 03 2022 07:16 PM
ronsway Offline OP
It has a torque tube. Can't turn driveshaft. you can feel it move when you turn wheels.
How much "free play" should there be when you move rear wheel before you feel drive shaft move?
Also, when I turn the wheels you can hear a soft ratcheting sound coming from driveshaft.
I don't know if I have no problem, small problem or a big issue.
ronsway #1469429 Mon Oct 03 2022 07:24 PM
I think you'll have to remove the u-joint cover and inspect that. If the shop didn't refill the u-joint bell it may have already worn out. It's a bushing type u-joint (no needle bearings like modern u-joints) and relies on the transmission lubricant in the rear half of the transmission for lubrication. It's also possible that the shop didn't get a seal behind the new torque tube/shaft bushing installed correctly and the lubricant has drained out into the rear axle. You could pull the rear differential fill plug to see if it's overfilled.
My money is on the u-joint being the problem.
I'm also suspecting that the "self clearing" comment by the shops was just a way to blow you off. nono Most noise issues don't fix themselves, especially ratcheting type noises. They usually get worse like yours has.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
ronsway #1469478 Tue Oct 04 2022 03:16 AM
ronsway Offline OP
Thanks, I am going to look at u=joint. The truck has a GMC 228 engine and a 4 speed. is the transmission the same on the GMC and Chev engines?
ronsway #1470623 Tue Oct 11 2022 02:03 PM
ronsway Better listen to klhansen,that ratchetting noise was probably the no rollers u-joint being killed by no lubrication. Is now loose enough to give vibration. Once had a farm truck dry tranny that squalled terible,went to drain it no oil,filled it waited overnite just fine the next day.
ronsway #1470934 Thu Oct 13 2022 01:01 PM
ODSS Lawman
The transmission for GMC and Chevy are the same.
As stated above, the u-joint ball needs about a pint of gear oil. It is often forgotten......
Question: If you drive over 45 to 55 does the noise go away or get louder???
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1950 GMC 450 (25% owner)
1951 Chevy 1/2-Ton
The GreenMachine
In the Stovebolt Gallery [stovebolt.com]
Moderated by  SWEET
