The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (Sir Duke), 102 guests, and 3 robots.
Forums60
Topics127,654
Posts1,046,323
Members46,391
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
JW51 #1468322 Mon Sep 26 2022 07:35 PM
Ex Hall Monitor
Hardware more frustrating than an E clip? In my case that would be the piece of hardware Du jour. Any piece of hardware I ever try to use seems to have a pact with the Devil to make my life as complicated as possible.
Let's go Jared!
JW51 #1468329 Mon Sep 26 2022 08:05 PM
JW51 Offline OP
I always understood the Jesus clip to be the wire type clip used in retaining some transmission cooling lines. I’ve had a go around with that clip as well.
It’s definitely no less evil than the classic e clip.
Tiny #1468333 Mon Sep 26 2022 08:20 PM
JW51 Offline OP
I recently discovered a life-changing tool known as long reach hose pliers. They all but eliminate frustration with hose removal and can even be made to loosen a spring type clamp in an impossible location.
However, aside from HRL’s suggestion of the modified slip joint pliers, I have yet to come across a tool, or a YouTube video that claims victory over the e-clip.
JW51 #1468379 Mon Sep 26 2022 11:53 PM
I
Retired Construction Worker
This might not be found in a lot of hardware stores ,,but just recently I found a way to put a key on or off a key ring without splitting my thumb nail ..it called a staple puller ..
Directions are just another mans Opinion
JW51 #1469292 Sun Oct 02 2022 10:37 PM
There is one which comes close if not surpasses the e-clip.
It is the dang-it clip (cleaned it up for the sake of the children).
It goes in a groove in the end of the piston to retain the piston pin in a small 2 cycle engine. It is tiny and when you finally dig it out, it has a propensity to end up in your eye before you can close your eyelid. Had one hit my left eye dead center, scratching my cornea pretty good.
Page 2 of 2 1 2
Moderated by  Justhorsenround
