The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (WE b OLD), 60 guests, and 3 robots.
Forums60
Topics127,654
Posts1,046,324
Members46,391
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1468559 Tue Sep 27 2022 09:47 PM
MattMcK Offline OP
I have an old edbro pto that someone hooked up to my truck for the dump bed but never connected it to anything. I have a cable in the cab from a previous pto that i would like to use. The actuator switch pivots down in a half circle so im wondering if anyone has a good way to hook it up.
59 chevy Spartan 100, former firetruck
348ci with spicer 5 speed and electric rear
MattMcK #1468596 Tue Sep 27 2022 11:27 PM
Turn by hand and fool with the switch while operating!
Ed
MattMcK #1468746 Thu Sep 29 2022 02:07 AM
Hard to tell with just one picture, but do you have the shift lever on the PTO control shaft?
Mike B smile
MattMcK #1468872 Thu Sep 29 2022 09:27 PM
MattMcK Offline OP
Heres some more pictures. Its an edbro model 201 and has the pump integrated in the pto. I tried to show in the pictures how it rotates down in a half circle and has that tab on the top that can pivot to either side. Im going to try to use the old cable from the firetruck pump to actuate it. If i cant figure it out, I may rip a pto off a truck at the scrap yard instead.
MattMcK #1468914 Fri Sep 30 2022 01:48 AM
Does that little swivel lever need rotate 180* to move the driven gear in and out of gear? If so, that will make linkage hard to configure so it works smoothly.
When searching for another PTO, make sure it's from the same model transmission as the driven gears are not all the same and won't mesh with your drive gear.
Mike B smile
MattMcK #1468940 Fri Sep 30 2022 12:14 PM
Mark the trans. it come from while fresh in your mind.
I always mark PTO’s when removed as like Mike says all drive gears are different and no-one has any books now that contain that info!
Ed
MattMcK #1469009 Fri Sep 30 2022 08:42 PM
MattMcK Offline OP
It seems like it does need to rotate the full 180* to engage/disengage. There seems to be a spring/detent at either end of the stroke.
That is good to know to pay attention to the gears. This pto isnt even from this transmission and hasnt been engaged to my knowledge. Is there a good way to double check that it will work? Measure angle of teeth and spacing?
MattMcK #1469015 Fri Sep 30 2022 09:48 PM
The only way I can think of to know if your PTO will fit your trans is to drain the trans, pull the PTO cover off, hold the PTO up and see if the Drive Gear and Driven Gear meshes. If you install a couple long studs you can be sure you have everything lined up as you check the fit. The gear backlash is adjusted by adding gaskets.
Note, the 6-bolt mounting pattern is an SAE standard used by everybody, so you can't go by that to say it fits or not, it's all about the gears...
Mike B smile
MattMcK #1469020 Fri Sep 30 2022 10:22 PM
MattMcK Offline OP
Well luckily for me, the pto is already off so i could figure out how it worked! Unfortunately, there isnt an output shaft on the pto that i can wiggle to check backlash since its all enclosed. Guess ill have to do that another way.
MattMcK #1469024 Fri Sep 30 2022 10:32 PM
I don't think you mentioned what transmission are you putting it on?
Mike B smile
Page 1 of 2 1 2
Moderated by  SWEET
