The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (Sir Duke), 111 guests, and 2 robots.
Forums60
Topics127,654
Posts1,046,323
Members46,391
Most Online1,229
Jan 21st, 2020
Page 4 of 5 1 2 3 4 5
pvfjr #1159623 Sun Apr 10 2016 11:04 PM
Is the tranny in your 55.2 Chevy 6400, or another truck ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
pvfjr #1159633 Sun Apr 10 2016 11:55 PM
The problem with any 5 speed OD trans, is to make 5th OD in the direct 4th gear position, is they make OD the 3rd gear position, so there is a tremendous gap between 2nd and 4th, with a load, one cannot frequently make that jump to 4th., unless a two speed rear, so one is 2nd gear bound until the road levels out.
Makes it even worse with the closer ratio gears required with a diesel. On my 1 ton KB-5 with a 345, I changed out the trans to a direct 5 speed and changed the diff. ratio, much more useable setup.
Ed
spanky #1159638 Mon Apr 11 2016 12:33 AM
pvfjr Offline OP
Yeah, so far that's the only old iron I have.
pvfjr #1159714 Mon Apr 11 2016 08:10 AM
The old Clarks had the shift pattern you posted. The good thing about them was that if you got stuck, you could go back and forth from 1 to R and try to rock yourself out. Overdrives were very rare. Chances are good you have a direct.
crenwelge #1160503 Fri Apr 15 2016 06:40 AM
pvfjr Offline OP
Well I managed to rid the truck of its infestation related debris and get the old carpet out. The tranny tunnel came out without too much fuss. From the top, the tranny looks even more like the 205/207 case. I wonder if there were any castings or stampings that would differentiate them. I do see a couple castings in the new photos toward the end of the album, but don't know what they signify.
5 speed pics
pvfjr #1160656 Sat Apr 16 2016 01:25 AM
Casting numbers won't do much good because the direct and OD are built in the same case. 50 years ago it was common to change a few gears in a Clark and make an OD out of it. GMC would have a line set inside the glove box door. I don't know much about Chev. If all else fails put it where 4th would be on a direct.
2 4 R
|_|_| Direct Drive 5th
3 5 1
Turn the input shaft. If the output goes slower than the input, you have a direct. If it goes faster, you have an overdrive.
pvfjr #1468486 Tue Sep 27 2022 02:14 PM
4 shift rails and Al top cover sure clues. 540 series as well as 465’s are all easy to downshift into low, just practice.
Ed
pvfjr #1468883 Thu Sep 29 2022 10:13 PM
Does have provision for PTO on both sides which the NP540 has.
BC
1960 Chevy C10 driver 261 T5 3.73 dana 44
1960 C60 pasture art
EdPruss #1468908 Fri Sep 30 2022 01:16 AM
Ed
You do realize this is a 6 year old thread, right?
Mike B smile
pvfjr #1468921 Fri Sep 30 2022 04:12 AM
Still working on days of the week, now you want me to notice the year?
BC
Moderated by  69Cuda, Grigg
