The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (Sir Duke), 102 guests, and 3 robots.
Forums60
Topics127,654
Posts1,046,323
Members46,391
Most Online1,229
Jan 21st, 2020
#1465288 Mon Sep 05 2022 09:08 PM
Former BMW Rider
I've been helping my neighbor with his '72 Nova SS, 454 big block. It's got a lot of electrical issues that I've traced back to the fuse block, which is a rusty mess. For example, the turn signals are currently powered by an ignition wire (hot with key on) from the fuse block. So at least he has turn signals.
Anyone have a good method of cleaning those rusty fuse holders? I'd like to be sure all the circuits have power and new fuses before going much deeper, thanks.
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
back yard wrench turner
A good cleaning with a pencil wire brush and damp baking soda should do the trick. Rinse with water and blow dry. Dielectric grease applied should finish it off.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
I have more zippers then a pair of cargo pants
There are companies that make fuse box repair kits that include the terminals for the glass fuses and bulkhead terminals….. joe
Donate Blood, Plasma, Platelets & Sign Your DONORS CARD.
The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist:
Either we are alone in the Universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Former BMW Rider
Those are great suggestions fellas, thank you both. Let me say again, this fuse block is a rusty mess and by all rights should be replaced. If I'm successful with the clean-up, I'm certain this is a band-aid fix before the ultimate replacement solution.
So, I got my hands on a donor fuse block and tried a Dremel tool. It's basically a round grinding bit. It fits the fuse clamp quite well, especially the rounded arc of the clamp where the fuse makes its connection. The bottom fuse holder was cleaned with the Dremel tool and the on above wasn't cleaned. There's a notable difference as you can see. See the attached photo. GM Fuse Block Cleaning [flickr.com]
Do you think the Dremel tool is too aggressive? I plan to follow-up with some dielectric grease on the fuses to slow the subsequent and inevitable rusting process.
Andy
Andy,
That looks pretty good. My boat had glass fuses, and I ditched them for Blue Sea Systems fuse blocks that use ATC style fuses when I started having electrical issues. Much better. But your neighbor probably wants an original.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Former BMW Rider
Thanks Kevin, I'll give it a try and use a very light touch to shine things up a bit. It could only improve the situation from where it's at right now. He does want to stay pretty close to original, but that might change.......
Andy
Socket Breaker
good forum for those:
https://www.stevesnovasite.com/
or it used to be at least, it was bought out by Vertical Scope like a whole mess of forums from the last few years.
-Woog
Former BMW Rider
It's still a good forum. Thanks Woogeroo!
Andy
Moderated by  Justhorsenround
