Holidays are over
Hunkering down for winter ... how about your truck?
Forums59
Topics128,266
Posts1,053,224
Members46,580
Most Online1,229 Jan 21st, 2020
OP
Retired Construction Worker
a guy I worked with had one and he traveled in constructon from job to job living in it ,, That was back in 1971 and I have not seen one since/.. he had a big Chrysler Emperial .. Did they get outlawed like they should of is the reason why I never seen another? https://photos.app.goo.gl/po2TUQg18sCbbeeKA
Directions are just another mans Opinion
BC 1960 Chevy C10 driver 261 T5 3.73 dana 44 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022
I wonder what those rain gutters are rated at? Do you think they are class 2?
I wonder what those rain gutters are rated at? Do you think they are class 2? OH, they have to be at least Class 3.  That's scary
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Seen a couple VW Bugs with a set up like that. I have to assume some engineer on crack came up with this, and it went into production for about a year before the DOT shut it down.
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces. Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
OP
The one I seen was down river from Portland Oregon where I used to live,, town called ST Helens not very populated ,,so at the time I was thinking that there must be lots of them in areas where more camping was .. Ferris , I think like you ,,some one surely had to shut the idea down.. I do remember guys at work when we all seen this guys car and fifth wheel set up ..shook our heads .
Think about that thing in a panic stop- - - - -even with trailer brakes! I've seen a 1 ton dually pickup with a BIG horse trailer set up that way, but the superstructure surrounded the body and went all the way to the frame with a commercial 5th. wheel mounted on top. Watching the guy do a 180 with the tow rig and park the trailer in a tight spot was really entertaining. Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
OP
Yes Jerry ,, can you just visialize the roof panel crumpling up after a hard stop ..?
Wonder how many people volunteer to sit in the back seat?
Evan
