Well the boys got the first layers of grim scrubbed off, and we pulled her in the garage. After a lesson on shop safety and how to properly use a lift we started the inspection process and began a list of what needs to be done first.
We pulled one wheel and pads and drums look good. Someone had done brake work at some point and the wheel grease still looked clean and red so that's a good sign.
For starters:
Brakes: A master cylinder, 4 new wheel cylinders, All new hoses, lines , and fittings.
Parking Brake: Lever has a rod running back and the two pullies up on the frame that look pretty crusty. I'll need everything else. Looks like two brake cables, some pins, and felt seals where the cable bolts to the backing plate. Not sure what else but that's a start.
Rear Axle: got some Thick oil/ grease seeping from what looks like the axle housing outboard of the leaf spring right at the U bolts. I'm hoping its a vent or something and not a cracked axle? It's not at the end of the housing where the backing plate attaches. To much old grease and gunk to really see what's going on yet.
So Brake lines, I've used regular and the copper-Nickle. They both have there place, what about SS? I might give it a shot. I've got a great flare tool so that's not an issue. Any thoughts?
Man! check out those sexy rear shackles!
Time to start ordering parts for next weeks class.
