The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 77 guests, and 3 robots.
Forums60
Topics127,654
Posts1,046,323
Members46,391
Most Online1,229
Jan 21st, 2020
#1466690 Fri Sep 16 2022 03:11 PM
Getting to where most shop projects are old hat that's been repeated many times but a couple of "first time" this week. Called FiTech on the three throttle bodies on a 406 Ford and was told to keep a record and then let THEM know. Putting a 1956 265 Chevy engine in a bucket T. Didn't want to buy pricey no side mount bracketry for a 265 so Marine-Tex was used to GLUE side mounts to 265 block. Keep tuned.
Evan
coilover #1466702 Fri Sep 16 2022 04:31 PM
Why not find a threading tap that will fit a freeze plug hole and fabricate a mounting point that will SCREW into the block? That's bound to be stronger than some kind of glorified Gorilla Glue! It would take me about three hours to fabricate a clone of the old Hurst straddle mount from 1/4" steel plate that uses flathead Ford motor mounts and bolts to the front of the block- - - -less if I used a plywood template and a plasma cutter.
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
coilover #1466743 Fri Sep 16 2022 07:41 PM
With enough surface area and CLEAN surfaces, I predict that "glorified Gorilla Glue" will hold for years. Way easier than messing around for even 3 hours to fabricate a bolt-on mount. Marine-Tex and other epoxies are good stuff.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
coilover #1466784 Fri Sep 16 2022 11:23 PM
If someone will give me a SIMPLE way to post a video I will bond a mount to an old junk block, chain block to welding table and use our pulling port-o-power to test the bond. I have a $100 that says it will pull the side out of the block before the bond fails. Chevy pickup door hinges, space rockets, and modern airliners are all "glued" so I think chances are on my side. It has replaced weld, rivets, and bolts in many applications.
Evan
coilover #1466787 Fri Sep 16 2022 11:31 PM
A 1 1/4" NPT pipe tap will thread a 265 freeze plug hole with about 10 minutes' worth of work. (Just looked up the dimensions) That's just a different possibility that I'd trust more than a glued-on motor mount. Of course, this one probably isn't going to be turning laps on a 1/4 mile dirt track at 6K RPM, right? Maybe Moose Juice will work! I think I'm going to try screw-in block plugs the next time I build a small block Chevy, just to mess with the mouth breathers at a car show.
LOL!
Abraham Lincoln
Ernest Hemingway
Moderated by  Justhorsenround
