The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
16 members (55shaker, KEVINSKI, Donf, FAST55, Hotrod Lincoln, crenwelge), 200 guests, and 5 robots.
Forums60
Topics127,667
Posts1,046,513
Members46,401
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1464707 Wed Aug 31 2022 05:31 PM
I'd love to see a picture of a rod that runs between the accelerator pedal and the bellcrank, that works nice and smooth. Th rod that came with my truck had a large sweeping curve in the large cab end when I got it. I straightened it the 3 inches or so at the top, and it will work now but is still just a little too stiff to slide smoothly. I have been eyeballing it, and trying to find signs of where it's rubbing, and bending accordingly. It just seems like common sense, but so far mine hasn't kicked in completely. Pics, tips, hints, etc all appreciated.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
1950 Studebaker Starlight Coupe
Mike Burns #1464728 Wed Aug 31 2022 09:29 PM
Curmudgeon
Truck pics.
Mike Burns #1464746 Wed Aug 31 2022 11:34 PM
Mine looked very much like the one in the factory drawing, before I started straightening portions of it. I guess that I probably should have left it alone. I don't really remember why I thought that it needed altered. Anybody have any recommendations on how to put the original curve back on it??
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
Mike Burns #1464751 Thu Sep 01 2022 12:16 AM
Use pipe bending coil of the correct inside diameter. It's used for putting curves in copper pipes without creasing or bending them.
https://www.lowes.com/pd/Kobalt-Spr...Nr7sX4BAuwaAjehEALw_wcB&gclsrc=aw.ds
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Mike Burns #1464755 Thu Sep 01 2022 01:12 AM
A pipe bending coil won't work very well unless it's inside the tubing. Not really possible with the accelerator rod.
A bending jig made from a disk of wood of slightly smaller radius than desired to allow for some springback. A sandwich around that disk would be good to keep it in line. Kind of hard to describe in words, but here's a sketch.
I could dig mine out and figure out the bend radius for you.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Mike Burns #1464758 Thu Sep 01 2022 01:27 AM
By altering the bend of that thick part, you have destroyed the geometry that was engineered into this setup.
SInce the end of that rod is bolted to the pivot bracket on the back of the gas pedal and the pedal is hinged at the toeboard, the pedal swings forward on an arc.
The curved bend in the rod is there to accommodate the arc in the swing of the pedal to avoid contact with the hole in the toeboard.
If one has a need to alter one of these rods to work with a non-stock engine, bends and extensions need to be limited to the skinny part of the rod.
It is also important that the skinny part of the rod travels in the same direction/angle as the original.
Failure to do that will also result in destroying the geometry of this rod.
Mike Burns #1464770 Thu Sep 01 2022 02:34 AM
Thanks guys. I understand all of your replies. As I said earlier, I should have just left it alone. But it did not slide through the toe board smoothly enough to use at that time either. So, maybe it wasn't correct as original manufacture anyway. In any case, I'll get it figured out eventually. Thanks for the responses.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
Mike Burns #1464830 Thu Sep 01 2022 05:07 PM
Curmudgeon
Just an idea.
The accelerator rod, that goes through the floorboard, moves through a thick felt seal.
Remove the seal and test the movement.
If the linkage is free, the rod may be riding against the seal causing significant drag because the rod alignment is not correct.
The link is a picture of a new seal, for reference only.
https://www.ebay.com/itm/122328548165
Mike Burns #1464837 Thu Sep 01 2022 05:31 PM
I added heim joints/rod ends to each attachment point of my accellerator rods, now smooth as silk. I see trucks all the time that are still running original rods which are nearly worn through. There are rod ends available at most hardware stores, also search Speedway motors for their assortment.
https://www.speedwaymotors.com/the-toolbox/rod-end-and-heim-joint-buyers-guide/28762
1946 1/2-Ton Chevy [stovebolt.com]
1953 Chevy 3/4-ton Factory Stakebed [stovebolt.com]
Mike Burns #1464843 Thu Sep 01 2022 06:26 PM
Curmudgeon
Well excellent! Please post pictures of what you have. I for one would like to see how it is done.
Page 1 of 2 1 2
