The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
13 members (KEVINSKI, Marty_in_Mesa, Hotrod Lincoln, JoeDude, 2-Ton, 1 invisible), 185 guests, and 3 robots.
Forums60
Topics127,668
Posts1,046,516
Members46,401
Most Online1,229
Jan 21st, 2020
#1464752 Thu Sep 01 2022 12:48 AM
Can the harmonic balancer from a 1941 - 216 be used on a 1961 - 235? I'm swapping the 216 for the 235 and want to be able to keep the wide belt to appear as nearly stock as possible. I'm using the 216 valve cover.
ponder48 #1464754 Thu Sep 01 2022 01:12 AM
The balancer will fit, but the position of the water pump on the newer engine cannot be hidden, even with Dave's relocation adapter and the 216 water pump. Ray Charles could "see" the difference! What do you plan to do about the pushrod cover height difference?
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
ponder48 #1464775 Thu Sep 01 2022 03:15 AM
They used different dampers for a reason, begining in this case with different stroke lengths.
ponder48 #1464781 Thu Sep 01 2022 06:06 AM
Inline sixes are inherently balanced, so the "different stroke" idea doesn't hold water. 235's from 1941 to 1953 ran the same balancer as a 216. Six cylinders including 216, 235, 194, 230, and 250 all have the same diameter crankshaft snout (1 1/4") as well as most small block Chevy V8's. All the balancers for those engines will press fit onto a stovebolt crankshaft, but they won't necessarily have belt grooves that line up properly. Some have bolt-on pulleys.
Abraham Lincoln
Ernest Hemingway
ponder48 #1464825 Thu Sep 01 2022 04:40 PM
Not completely. There is no mass directly opposing the crank throw.
Stroke changes crank stiffness, which is what determines harmonics.
http://harmonicdampers.com/downloads/pdf/tech/BHJDynamics_Damper_Info.pdf
Hotrod Lincoln #1464829 Thu Sep 01 2022 05:06 PM
Well, some things will just hafta look non-stock as in the case of the push rod cover. I'm a pragmatic idealist - everything should be perfect, but it ain't. There will also be a split exhaust and a dual carb intake. You might ask, then, "Why do you want it to be as close to original as possible?" I've asked myself that question already and can't answer myself. At my age and with south Georgia heat this is a slow process, so some things will probably change. Anyway, I really do appreciate your advice - it answers my question.
ponder48 #1464869 Fri Sep 02 2022 12:11 AM
I can offer a few suggestions by private message if you like. I've done a considerable amount of experimentation on stovebolt balancers, and I might be able to offer an alternative to a 70 year old item that would allow you to run a wide belt with a newer part.
Abraham Lincoln
Ernest Hemingway
