Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
4 members (Atticusnine, baldeagle, 2ManyTrucks, Hotrod Lincoln), 59 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,565
Members47,279
Most Online1,229
Jan 21st, 2020
Page 4 of 4 1 2 3 4
Okaaay! We haven’t had enough sun to test the PLA filament for UV affects. However For heat affect I can tell you it is very durable. I had this next to a space heater and also used a hair dryer to dry the paint.
Do not use any other paint than acrylic for plastic. As you can see the paint (maroon) I used for Stovebolt ran, and the blue crinkled when I applied the clear coat.
I believe the acrylic paint and clear coat will sufficiently protect from sun UV affects.
Let me know if you are interested by PM.
Edit: The new toppers are $20. The PLA filament is not as expensive as the PETG. We will replace, for no charge, any that get broken or stolen.
53 Chevy 3100
“Old Blue”
AD Addict
I printed a radio blank off plate for my ‘52 made of PLA and I painted it buildable primer and Ace Premium spray paint. I had no issues with it affecting the PLA.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Phak1, nice looking radio delete plate.
It wasn’t the paint affecting the PLA that was the problem. It was the coats of clear seal that affected the paint I used. Hobby Lobby model paint crinkled and ran.
The known problem with PLA filament for outdoor use is that UV rays from direct sunlight will will cause it to warp.
I am hoping the clear seal coat will protect it from the UV affects of constant sun exposure. We used PETG filament before however it is harder on my grandson’s 3D printer. (Had to replace the nozzle after a couple printings.) It’s not a high dollar top of the line printer.
The toppers were something my grandson wanted to do for the Southern Stovebolters. They have been great at making him a part of the gang at our outings.
53 Chevy 3100
“Old Blue”
back yard wrench turner
Papa Joe, sent you a PM
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
Just a quick note… I think I posted this before, but wanted to be sure… To all those who have purchased toppers and emblems from us, they have a lifetime warranty. If your topper/emblem gets damaged or warped for any reason we will replace it free.
Thanks, PaPa Joe/Eli
53 Chevy 3100
“Old Blue”
I did a thing.
My license plate topper has been sitting on the shelf ever sInce I painted the thing. Today I made a thin metal backing plate which I epoxied to the back of the topper to add stiffness so it would be less likely to break.
I then proudly mounted it to my Cowboy Cadillac front license plate (won’t fit in the back). Show your off! I dare ya!
Page 4 of 4 1 2 3 4
Moderated by  Achipmunk, TUTS 59
