The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (2ManyTrucks, 32vsnake, 59 fleet, DonBolt, delky, dougs, 1 invisible), 108 guests, and 4 robots.
Forums60
Topics129,204
Posts1,047,808
Members46,221
Most Online1,229
Jan 21st, 2020
#1459185 Mon Jul 18 2022 03:14 PM
I'm in the need for a a/c relocation bracket for a 1995 lt1. (To mount high on drivers side). These are commonly referred to as "Bowers brackets." Bowers Rod Shop no longer makes this item due to historically low sales. Hopefully, someone may have one that they're willing to part with.
Crusty Old Sarge
If you can't find anyone with a bracket you may want to try Alan Grove Components. They have several different set ups.
Craig
Come, Bleed or Blister something has got to give!!!
Curmudgeon
Rocketman I read your posting at https://www.ls1lt1.com. Hmmm. You have my kind of luck.
Bowers is still in business, but not making the bracket you want, because no one was buying them.
You could piece together used high dollar Corvette parts or buy billet parts but they cost an arm and a leg. You are not making a "show" engine.
You want a decent bracket that mounts high on the driver's side so you don't have to do weird stuff like notching the frame or cutting the inner fender.
I tried to find a picture of what the bracket looks like. Is this it?
Have you tried calling the owner of Bowers Race & Rod Shop?
Be humble (you know, beg) and ask if he could help out.
Ask for any stray parts left over from a kit he may have lying around or maybe some drawings would be nice.
Yes, I spoke with the owner. We talked for a few minutes ...I think he "felt my pain". He said that he sees his bracket show up from time to time on ebay. Yes, your attachment is what I need!
Curmudgeon
Keep your eyes peeled.
The construction of the parts may not be terribly bad but the measuring and getting the correct dimensions, from the get-go, is the hard part.
If it's not right, belt alignment will be an on-going headache.
Moderated by  Gdads51, John Milliman
