The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
9 members (1pete1, NorthCoast3800, Marty_in_Mesa, Challenger Pilot, panic, Maybellene), 162 guests, and 3 robots.
Forums60
Topics127,668
Posts1,046,517
Members46,401
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1458614 Wed Jul 13 2022 12:16 PM
8
87GN Offline OP
nothing beats a try but a failure
My new 235 has an oil leak. Oil is found on the block at the edge of the head, passenger side, about mid way from the front to the back. The valve cover is sealed and not leaking. Head was checked for cracks, had none. The head is rebuilt and decked, same as the block. Has any one had this oil leak and if so can it be fixed?
1955.1 3600 5 window 4 speed all original.
87GN #1458615 Wed Jul 13 2022 12:22 PM
AD Addict
Can you post a picture of the leak?
Phil
Moderator, The Engine Shop & Interiors
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
87GN #1458618 Wed Jul 13 2022 01:00 PM
Is it near the coil bracket? I had to reseal the bolts holding my coil on and it solved one of my leaks.
1955 First series 3600
87GN #1458620 Wed Jul 13 2022 01:24 PM
The coil mount bolts enter an oil passage?
87GN #1458621 Wed Jul 13 2022 02:04 PM
We use an indicator dye and a UV light for oil, coolant, or refrigerant. Shows EXACTLY where leak is.
Evan
JW51 #1458623 Wed Jul 13 2022 02:14 PM
They go through a thin casting into the valve valley that holds the rocker arms. It's not pressurized, but splash oil can seep through the threads unless you put a little LocTite or some other sealer on the bolt threads.
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
87GN #1458638 Wed Jul 13 2022 04:38 PM
Hm. I’ve got some wet look back in that area that I assumed was a valve cover seep.
Learn something new every day.
87GN #1458652 Wed Jul 13 2022 06:16 PM
Makw sure the hex plug at the midde center top of the head, pass side, is tight and not leaking.
Mike
87GN #1458659 Wed Jul 13 2022 06:27 PM
My 235 is always “sweating horsepower” and it’s hard to figure where one seep ends and the next begins.
One of these days, I will start tracking down the source. But as it is today, it rarely swears enough to leave more than a drop on the floor.
87GN #1458662 Wed Jul 13 2022 07:01 PM
If it is leaking right in the center of the head on the passenger side (where the head meets the block), there is an oil passage there. It leads up through the head and on from there to the rocker arm shafts (to lubricate those). If the head gasket wasn't sealed (even if the block and head were decked) I've seen 235s leak right there. Usually this is a seeping leak. Especially if your 235 was rebuilt to factory specs. By that I mean the proper bearing to crank tolerances, new cam bearings, new oil pump, etc...that will cause you to have a nice amount of oil pressure and it can seep out at that passage.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Page 1 of 2 1 2
