The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (jameschevypu50, 87GN, Justhorsenround, 49choptop, coilover, 2 invisible), 129 guests, and 3 robots.
Forums59
Topics128,597
Posts1,041,768
Members46,055
Most Online1,229
Jan 21st, 2020
#1456384 Sat Jun 25 2022 06:11 PM
I am cleaning my sm420 trany up and installing new gaskets. I saw online that there is an upgrade to the front shaft by Novak that replaces the front input housing, and they grind a new seal area on your own shaft. I have the ability to do this myself, as, I have a universal tool and cutter grinder, a nice Romi lathe and Bridgeport mill. I can grind the shaft between centers, make a new input housing, and install a new lip seal. Has anyone done this upgrade recently? I would need the seal number, and the shaft dimension, that way I can do it myself. This is a 1948 sm420 that is in really great shape. I am also considering a Gear Vender overdrive unit. The truck is a 47 3600 with the 4:56 ratio, but in very good shape too. I found a 4:11 center carrier, but the guy is a little hard to deal with, so an overdrive will be my next choice for better road drivability. Any info will be appreciated.
lumbersawyer #1456385 Sat Jun 25 2022 06:28 PM
Instead of fabricating a new bearing retainer, why not simply machine the old one to accept a seal? I'd be tempted to clean up the OD of the input shaft to get it round, and press fit a thin machined ring onto the shaft to act as an inner seal surface, also. Bearing and seal manufacturers such as National, Chicago Rawhide, and SKF publish progressive size charts for seals that list the ID and OD, as well as the lip material and design. Just pick one that meets your needs. Since the SM 420 has survived for decades without a front seal, not all modifications are "improvements"- - - -especially if you're not going to encounter extremes of up and downgrades like the rock crawlers do that might let the lube leak out of the front of the housing.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
lumbersawyer #1456421 Sat Jun 25 2022 10:45 PM
Well, I went out just for fun and machined a left-hand internal sleeve to fit on the input shaft. It fit the first time trying the shaft into it...That has happened more than once when I make threads for special nuts. So, I'm not sure what I'm going to do yet, but it was fun to run my lathe and challenge myself. Jerry, the bearing retainer does not look to be thick enough for a seal counter bore. It is only about 1/8" thick between all the dimensions. With the bearing nut and the oil slingers, not much room left to fit a seal in it.
lumbersawyer #1456424 Sun Jun 26 2022 12:07 AM
The newer sm420 have a seal you may be able to find the front retainer for a newer one mine is a 67 or 69 transmission ,also has the reverse switch on the top cover the seal is available.
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
lumbersawyer #1456773 Wed Jun 29 2022 01:25 AM
I've run an SM420 for 50 years with no seal. It doesn't leak as far as I can tell, even when parked nose-down on a steep hill. Does yours leak now?
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
lumbersawyer #1456782 Wed Jun 29 2022 02:03 AM
I have not run the truck yet. The transmission was covered in greasy dirt so I thought it might need some new gaskets and maybe a upgrade to the front seal.
lumbersawyer #1457486 Mon Jul 04 2022 08:09 PM
I ordered a new bearing retainer front for my SM420 From Novak. It came with a standard input seal in it, but mine being an older trany the seal will be replaced with a 1 1/8" bore instead of 1 1/4" that the newer trany must have. I machined the left-hand threads back to get a very nice area for the new seal. So my new seal is 1.750 OD X 1.125 ID X .250
Moderated by  SWEET
