I’m swapping ring gear and pinion because the pinion in the rear end has chipped teeth. It looks like I will be learning about how to install and adjust the set and backlash. What can I use for the tool to tighten the differential bearing nuts? I should mention that this is a torque tube rear end.
I invest my money in precious metals, mostly rust!
I used a screwdriver and a hammer to tighten the nuts. So far so good. I took a test drive and it seems good, maybe a little backlash but no worse than other old rear ends.
Pin-type spanner wrenches are all over Ebay, both fixed span and adjustable types. The thin open end wrench in the picture is used to adjust preload on the pinion bearing, not the carrier bearings on both sides of the ring gear. I learned to adjust the ring gear backlash by moving the carrier assembly back and forth and checking backlash with a dial indicator, and then tightening both adjusting nuts one notch to preload the bearings. It's worked well for me that way since the mid-1960's. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
