HAPPY BIRTHDAY
C A N A D A
July 1
Over 2022 Bolters live "up over" ... a cool addition to the flavor of The Stovebolt Page.
Birthday salutes here!
Oh Lord, I just gotta find it....
Forums59
Topics128,032
Posts1,036,685
Members45,918
Most Online1,229 Jan 21st, 2020
OP
I've seen a gear corrector that corrects for the error in the speedometer when you change the differential gears from 4:11 to 3:55. I think I'd like to add one of these to my truck, assuming that they're still available. My question is: are they reasonably accurate, and mainly, do they hold up OK and last for a long time?
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1953 Ford Victoria 1950 Studebaker Starlight Coupe
Speedo shops can make up most any permanent ratio adapter for your new diff. ratio which is a routine operation for many trucks.
Ed
Way back when I changed my gears to the infamous 3:55, my local speedo shop was able to produce a gear adapter. The speedo reads dead on and it's been 15+ years. I periodically check all my vehicle speedo by using a phone app call Speedbox.
Craig's '50 Chevy 3100 5 window My truck If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Curmudgeon
https://www.bobsspeedometer.com/products/ratio-adapters/I haven't used them but they seem knowledgeable and willing to talk.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
Tim, Thanks for posting the link. Looks just like the one I'm using.
Craig, I have been using a similar ratio adapter since 2007.
As you know, if you use the measured/timed mile technique, that type of ratio-adapter adjusts for gearing and tires diameters.
I used bobsspeedometer for the factory speedo and tach in my fiberglass Chevrolet, I had put new needles on them and a new circuit board for the tach. I drove to his shop, told him what I needed, he looked at what I had in my hands and knew what they were from, calibrated them on the spot while I was there, didn't want any money for the work, I gave him some money and both units are still working after 20 years.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
I've also have done business with bobsspeedometer with good results.
Brian 1955.2 3100 Truck
