Forums59
Topics128,331
Posts1,054,142
Members46,614
Most Online1,229 Jan 21st, 2020
OP
Moderated
I’m new to the forum and wanted to I’ve learned a lot just by lurking. I’m a mechanic by trade but new to this old of iron. It’s now time to join and start picking brains. I inherited a project 1940 1/2 ton truck. The frame is completed and solid, the cab needs very little and aside from the forward bed panel the metal of the bed is also very good. The old 216 is a different story…. The main bearings are shot and after some research I ended up getting a hood running early 235 with pressure lube. I plan to keep the truck somewhat original as I’m not putting disc brakes on it or other mods. I plan to only use it locally pulling my outdoor cooker to events.
Where is a good place to post some questions about mounting the 235?
Moderator - The Electrical Bay and Rocky Mountain Bolters
Hello, and welcome to the 'bolt. You can post your questions in the general truck forum. You also might want to search the forums and maybe find some previous posts. Please post some pictures of your truck.
Another quality post.
Real Trucks Rattle
What year is the 235? In 1955 the water pump was moved to a lower position in the block which puts the fan too low on the radiator for your 1940 truck. There's a conversion plate made by a stovebolt forum member that allows the early style high mount pump to be used on the later block and puts the fan in the right place on the radiator. The front plate between the timing cover and the block might need to be adapted to use the early front motor mount, also. 1954 and early 55 235's had the 216 style water pump location, which makes them an almost drop-in fit for the 216. Welcome to Stovebolt.com where the inmates are running the asylum! Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
Grease Monkey, Moderator General Truck Talk & Greasy Spoon and HiPo Forum
Welcome to the Stovebolt madness. There is no cure!  Read through the different forums and decide which area best covers your specific question. By doing that you will be assured you are getting the expert answer to the particular question.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
OP
Moderated
Thanks, I was told the 235 was a 53 or 54 but I need to double check that
I would ask about that in the engine forum.
Real Trucks Rattle
Stovebolt Photo Moderator
Welcome aboard - I have a sister up in Maine, a place called Cape Neddick.
Socket Breaker
Welcome to the 'bolt.
To get started, jump in the Engine shop and they will get you on the right path.
-Woog
Welcome to Stovebolt family. We're here to help. Just post questions in the garage forums. See you around the forums.
