Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
19 members (Gdads51, Dusty53, COCOE, cmayna, 4 invisible), 161 guests, and 3 robots.
The Zone
Forums65
Topics123,390
Posts998,855
Members47,294
Most Online1,229
Jan 21st, 2020
#1452232 Fri May 20 2022 06:45 PM
Rmcea Offline OP
Hello everyone
I have an oil leak from the tailstock of my 50 gmc 3 speed transmission. I have heard that overfilling the trans could cause this .Any ideas on this and if so can the extra oil be drained. I know that there is a drain plug for the trans but will the oil drain from the tailstock. Any help would be appreciated
Bob
That leak is probably from the u-joint ball. There are cork seals that are prone to wear with the movement of the rear suspension and the torque tube. The whole area is typically covered with oil and dust and pretty grimy.
Overfilling the trans is actually pretty hard as the fill plug is the fill level. Fill it till the oil starts running out of the fill plug in the side. There's also a fill plug toward the rear that you could overfill (calls for 1/2 pint) for the u-joint housing. That could be overfilled, but it really wouldn't make much difference in the leak potential of the cork seal around the torque tube ball. You probably need to pull that off and get a reseal kit. Kind of hard to do with a complete truck as yo have to maneuver the torque tube up and down to get the ball housing off of it. There's a procedure in the shop manual to do that.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Rmcea Offline OP
Thank you
Curmudgeon
Example
