The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (gswbbc, Jethro in Va, klhansen, tom moore, 1 invisible), 95 guests, and 3 robots.
Forums59
Topics128,561
Posts1,041,530
Members46,043
Most Online1,229
Jan 21st, 2020
#1451883 Tue May 17 2022 02:07 AM
The 66 Lemans that came in the shop with an OHC I6 is getting close to leaving as a 67 GTO with an 800hp blown LS. Is a convertible so MUCH chassis stiffening was done and worked over fender wells to take big rubber. Customer wanted 700-750 rwhp but found a supercharger made in Australia by HARROP that has an over 70% thermal efficiency which means a couple more degrees of advance and a few more rpm so it looks like 800hp is expected. A turbo can be used with near off the shelf parts but a positive displacement Roots type gives instant brutal torque so driveshaft, differential, and axles are being upgraded. My old Cannon camera is getting temperamental and I don't know how to transfer pics to lap top from phone so I'll post them as soon as I can. On the other hand if you've seen one 800hp mid-60's GTO you've seen them all.
Evan
coilover #1451885 Tue May 17 2022 02:31 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Evan, toss your old Cannon in the trash and buy you a iPad. Even a slightly used one will do for photos. Take your photos then send them directly from your photo file to Stovebolt using the instructions posted in the left margin of every page. So easy even I can do it.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
coilover #1451887 Tue May 17 2022 02:46 AM
If you're trying to take pictures with a Cannon, you're probably using the wrong ammunition. wink
Cannon = Boom!
Canon = Click!
Sorry I couldn't resist. grin
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
coilover #1451904 Tue May 17 2022 09:35 AM
Camera shy.....I'm definitely Cannon camera shy. smile
RonR
1970 340 Duster
1951 Farmall Super A
coilover #1451923 Tue May 17 2022 12:21 PM
Coilover,
I would love to see these pictures!!!! I have a 77 Olds Cutlass I have always wanted to make into a convertible. Not a full mech, just a top that snaps in place or something like that to get me home if it rains.
That car would be so much more fun if it was topless.
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
coilover #1451940 Tue May 17 2022 04:03 PM
Ferris, you are correct about topless.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
coilover #1451948 Tue May 17 2022 05:25 PM
Ferris,
Home made convertibles can be a real can of worms. Factory ones have a much heavier reinforced frame and often torque boxes. The doors soon sag or are hard to open/close and an engine with any torque in your case maybe a 455 will soon have everything distorted. I have two Velveeta cheese boxes to show ones considering this; one has the lid on it and the seams taped, the other has no lid. The complete one does not twist easily while the open one is like wet spaghetti.
Evan
coilover #1451956 Tue May 17 2022 07:12 PM
Coilover,
I agree with most of what you say, howeverrrrrrr
The 77 Olds is a full truck frame car.
Mine has a ridiculous 260 V8 and a 2.73 Gearset.
Should not be any body issues. Might be a windshield issue?
coilover #1451987 Wed May 18 2022 03:54 AM
You're right!
Doing a pedal to the metal hole shot with a 260 would put the same twist on a frame as a 455 idling.
Evan
Moderated by  Justhorsenround
