Keeping your resto going
A good bit of advice nestled in the FAQ page.
Irwin Arnstein working on his 1959 Chevy 1-Ton
Read the article.
Forums59
Topics128,525
Posts1,041,265
Members46,037
Most Online1,229Jan 21st, 2020
OP
This master brake cylinder was recently pulled from my 1948 Chevy 1/2 ton truck. It's looking for a good home. Should be good for a rebuild. I took the wire wheel to it to clean it up a bit. You will need to finish cleaning/repainting it. You just need to cover the cost of the ride. LUKE
As I recall, Jerry was looking for one of these (Hot Rod Lincoln).
58 Apache, long bed fleetside, V8 w/SM420 Drivable but the rear axle needs work.
Luke, I’ll take and rebuild that master cylinder. I’ll PM you. Thanks
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod
OP
It arrived today! Thanks Luke for offering it on the Swap Meet forum rather than trashing it. I’ll restore it and put it to good use. Gotta love a Stovebolter!
