Oh Lord, I just gotta find it....
Forums59
Topics128,081
Posts1,037,106
Members45,928
Most Online1,229 Jan 21st, 2020
OP
Does the arrow on a residual pressure valve point towards the wheel or master cylinder? No instructions came with it.
When the foot is off the brake pedal, is the 10 lb pressure being maintained in the valve-wheel cylinder line or the valve-MC line?
Thanks!
1948 3/4-Ton 5-Window Flatbed Chevrolet [ sandeace.com] 29 Years of Daily Driving. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
The 10 lb pressure will be on the wheel cylinder side.
OP
There's an arrow stamped on the valve. Which was does it point?
Arrow is the flow direction, so toward the wheel cylinder.
Mike
