We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
frog farmer Are you quite certain if is mid-50's?? From the altered frame in 2nd pic it looks like an early 60's GMC. Sheet metal would be the same as 50's TF 3100's delkydave in wyo
I was told it was mid 50s when I bought it at an auction about 4 years ago. I figured the pictures would let somebody decide if it would work for them. The bed is approx. 50"X100". I used it to haul junk and rocks and branches to the landfill. I haven't needed it since retiring from Bullfrog farming last Oct.
frog farmer- The proof is in the frame and suspension. 55.2 thru 59 had leaf springs and 60-62 had coil springs & frame different from 55-59 delky dave in wyo
frog farmer-I have been around a couple of those early 60's beds made into trailers in past. Frame forward of bed is the give away. BTW -- both of those trailers had the limited slip differential ! delky dave in wyo
