The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Keep your restoration going
Keeping your resto going
A good bit of advice nestled in the FAQ page.
Don't
Irwin Arnstein working on his
1959 Chevy 1-Ton
Read the article.
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (Atticusnine, Hotrod Lincoln, Harold41, carryall jerry, Jimmie D, DES57), 108 guests, and 4 robots.
Forums59
Topics128,524
Posts1,041,185
Members46,036
Most Online1,229
Jan 21st, 2020
#1451355 Wed May 11 2022 04:48 PM
Good shape, side-mount spare, not rusty, needs new wood, tow it home. Located in Twin Falls, ID, $450.00
frog farmer
Are you quite certain if is mid-50's?? From the altered frame in 2nd pic it looks like an early 60's GMC. Sheet metal would be the same as 50's TF 3100's
delkydave in wyo
1957, 3100, v8
1990 Suburban
Definitely late 55 and later. Looks to be pretty solid. Believe the bed, less fenders, would work on a 54 or 55 1st 3100.
Ron
1954 Chevy 3604 - A work in progress...
Veteran, USMC
" You can't keep dancing with the Devil and wonder why you're still in Hell ! "
"Everything happens for a reason, sometimes the reason is you're stupid and make bad decisions"
I was told it was mid 50s when I bought it at an auction about 4 years ago. I figured the pictures would let somebody decide if it would work for them. The bed is approx. 50"X100". I used it to haul junk and rocks and branches to the landfill. I haven't needed it since retiring from Bullfrog farming last Oct.
55 to 62 is the script used on the gmc tailgate
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
frog farmer-
The proof is in the frame and suspension. 55.2 thru 59 had leaf springs and 60-62 had coil springs & frame different from 55-59
delky dave in wyo
1957, 3100, v8
1990 Suburban
Thanks Delky Dave, the GMC trailer has coil springs.
The wood bed is very usable and solid. Only "needs" new wood if being restored.
frog farmer-I have been around a couple of those early 60's beds made into trailers in past. Frame forward of bed is the give away. BTW -- both of those trailers had the limited slip differential !
delky dave in wyo
1957, 3100, v8
1990 Suburban
Moderated by  John Milliman
