The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy Birthday U S A !
Celebrating
Life, Liberty
and the
Persuit of Happiness
Happy Birthday
A M E R I C A
July 4 - 246 years
Stories, Pictures, Thoughts
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (MikeE, LexAdmn, Bruce36 1.5, KEVINSKI, Phak1, D B Cooper), 76 guests, and 2 robots.
Forums59
Topics128,080
Posts1,037,102
Members45,928
Most Online1,229
Jan 21st, 2020
Dusty53 Offline OP
Well, my vendor sent me unpolished bed angle strips and not the steel angle strips I actually ordered. I didn't open the box for 8 months and I'm stuck with them. With shipping and the cost of reordering I need to make these work. I'm competent with my MIG welder with 75% / 25% Argon Co2. What do I need to know? I figure I'll have to rough them up to get paint to stick to them so discoloration from welding is not an issue with me. Stainless is 430 . Help!
Ron
1954 Chevy 3604 - A work in progress...
Veteran, USMC
" You can't keep dancing with the Devil and wonder why you're still in Hell ! "
"Everything happens for a reason, sometimes the reason is you're stupid and make bad decisions"
Dusty, can you sandblast them...or someone that can. It'll give them enough tooth that the paint will stick.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Dusty53 Offline OP
Well after researching the welding and determining I need to get the correct filler wire, and then the time, travel , trial and error involved , I said to heck with it and ordered a set of steel angle strips from another vendor who had them in stock. I'm pretty sure I'd spent more money on just the filler wire and the gas to go get it....
Ron
Veteran, USMC
You've already decided on a solution, but you could probably have someone spot weld the angle strips to your bedsides. The discoloration at the spot welds can be polished out with a wire brush on a rotary tool.
Maybe post he stainless strips in the Swap Meet in case anyone wants them.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
I simply plug welded the strips to the bed, scuffed them down with 80 grit, then painted.
Seems to be holding up fine…
Mike
1940 Chevy 1/2 Ton presently in pieces...
1940 Chevy Business Coupe
Dusty53 Offline OP
Kevin, good idea. Funny thing, the "shipping cost" varies greatly by supplier as does the cost for these angle strips.
Ron
Veteran, USMC
I have no holes on my strips to mount to the bed side. I assumed I would need to drill and bolt to the bedside?
Are these supposed to be welded like OEM or can they be bolted?
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
They can be welded they .you can drill a hole in the box side and weld from the outside leaving the strip solid .On my 54 box side all but one hole is covered by the fenders or box side pocket .I think there is a write up on the mar k site.
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
On the ends where the stake pockets are, you'd have to drill the angle strip and weld from the inside, unless you are better than me at getting a MIG gun inside the stake pocket. wink
Moderated by  HandyAndy, klhansen
