The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (KevinW, Wrenchbender Ret., 67superc, tk261, papas52, JW51), 87 guests, and 3 robots.
Forums59
Topics128,612
Posts1,041,930
Members46,061
Most Online1,229
Jan 21st, 2020
#1451089 Mon May 09 2022 02:52 AM
doing the brakes on my 58 and one slave cylinder decided to leak in a previous thread I found the number for the rebuild kit Raybestos WK129 for a 7/8 bore does any one know a part number for a complete slave cylinder Thank You
hippydave #1451107 Mon May 09 2022 01:25 PM
3B Online
Hy hippydave, as has been previously discussed on this site, the original front wheel cylinders with the port straight out of it are no longer available. I suggested years ago swapping in the front wheel cylinder designed for the 1960 through 1965 60 series with a 5000 lb. front axle. Those wheel cylinders are the same in all respects except the port for the hose connection comes out of the cylinder at an angle, rather than straight out. At least a couple of members here have made that swap with no problems. The part numbers are, for Napa UP19090 for the left, UP19091 for the right, the Raybestos part numbers are WC19090 for the left, WC19091 for the right, hope that helps.
3B #1451157 Mon May 09 2022 08:12 PM
thank you for the info 3B
3B #1454954 Sun Jun 12 2022 09:59 PM
finally got a chance to change the front wheel slave cyl thanks 3B was a perfect fit and was done in 15 minutes once I got the 60 years of crud off
hippydave #1454987 Mon Jun 13 2022 02:37 AM
3B Online
Hy hippydave, I am so glad it went well!
Moderated by  69Cuda, Grigg
