The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Remember old days
Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to
The Wayback Machine.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Daves46pu, 3B, 66flea, FinnBolt, Curt B., Biggin69, 1 invisible), 103 guests, and 3 robots.
Forums59
Topics128,095
Posts1,037,203
Members45,931
Most Online1,229
Jan 21st, 2020
Lugnutz Offline OP
I was given a pair of Corvette aluminum rocker covers. One cover had a huge hole hogged in the top. I had a guy TIG weld it closed. He built up the weld and I carved out the C to make it say CORVETTE again.
I’ve polished aluminum wheels before, so I thought I’d give these a try.
The area between the fins is hard to polish, so I decided to “float” the fins and script with a background of black paint. I gotta say that they do ***SPARKLE*** a bit more than when I got them. Gotta do the other side now.
A big thank you to the generous donor - you know who you are!
Video showing before and after. [youtu.be]
Nice work. Your TIG guy (and you) did a good job on the hole repair.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
AD Addict
Looks great, nice work! thumbs_up
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Well Done they look great.
Brian
1955.2 3100 Truck
Lugnutz Offline OP
I polished the second one. It just needs black paint. I think the script and fin edges really stand out by adding the black paint.
Yep. Nice work
I was thinking to paint the letters and fins on mine contrasting color to the rest of the cover. I imagine what you did is easier cause you simply buff the color off the fin.
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
Lugnutz Offline OP
Finished the rockers covers. Just needs clear coat to slow down oxidation.
VIDEO showing BEFORE & AFTER [youtu.be]
Look'n good Jay!
Mike B smile
Crusty Old Sarge
Just a little bling, 283 is going to look great.
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
Moderated by  Woogeroo
