The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Celebrations!!!
HAPPY
BIRTHDAY
C A N A D A
July 1
Over 2022 Bolters live "up over" ... a cool addition to the flavor of
The Stovebolt Page.
Birthday salutes here!
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (fixite7, buoymaker, Bowtie john, bwilliams, GMCJammer51, 1 invisible), 105 guests, and 3 robots.
Forums59
Topics128,032
Posts1,036,687
Members45,918
Most Online1,229
Jan 21st, 2020
#1446736 Fri Apr 01 2022 07:45 PM
55-62 1/2 ton pinion flange. W/nut & washer. Needs speedy sleeve. GONE
Therm. housing. More 3/4 1 ton rear wheel brg. adj. locks.GONE A/C expansion tubes. White. Starter shim set. Off set. Brass drain cocks. 1/8 pipe thread.
Diff cover fill plug.GONE Gas pedal.(GONE) . Fan extension 1 3/4 thick. Master cyl bench bleed kits. GONE Fuel pedal studs. Turn switch ring.
George
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #1450108 Sun May 01 2022 12:18 PM
I’d take that pinion flange if it isn’t spoken for?
Wrenchbender Ret. #1450110 Sun May 01 2022 12:36 PM
Hello George, I would be interested in the 3/4 1 ton rear wheel brg. adj. locks and a Master cyl bench bleed kit if not spoken for. Thank you.
JW51 #1450136 Sun May 01 2022 03:31 PM
Its still available. Send me your address by private message & I will send it to you.
George
msmall #1450700 Thu May 05 2022 04:20 PM
OK I found some more spiders.
Send me an address by private message & I'll send them to you with the bleeder kit.
George
Wrenchbender Ret. #1451065 Sun May 08 2022 10:34 PM
If you have another bleed kit, I'd be interested.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
oldieoldie #1451112 Mon May 09 2022 02:05 PM
Sorry, I don't have any more bleeder kits.
George
Moderated by  John Milliman
