HAPPY BIRTHDAY
C A N A D A
July 1
Over 2022 Bolters live "up over" ... a cool addition to the flavor of The Stovebolt Page.
Birthday salutes here!
Oh Lord, I just gotta find it....
Forums59
Topics128,032
Posts1,036,687
Members45,918
Most Online1,229 Jan 21st, 2020
OP
55-62 1/2 ton pinion flange. W/nut & washer. Needs speedy sleeve. GONE Therm. housing. More 3/4 1 ton rear wheel brg. adj. locks.GONE A/C expansion tubes. White. Starter shim set. Off set. Brass drain cocks. 1/8 pipe thread. Diff cover fill plug.GONE Gas pedal.(GONE) . Fan extension 1 3/4 thick. Master cyl bench bleed kits. GONE Fuel pedal studs. Turn switch ring.
George
1972 Chevy c10 Cheyenne Super
I’d take that pinion flange if it isn’t spoken for?
Hello George, I would be interested in the 3/4 1 ton rear wheel brg. adj. locks and a Master cyl bench bleed kit if not spoken for. Thank you.
OP
I’d take that pinion flange if it isn’t spoken for? Its still available. Send me your address by private message & I will send it to you. George
OP
Hello George, I would be interested in the 3/4 1 ton rear wheel brg. adj. locks and a Master cyl bench bleed kit if not spoken for. Thank you. OK I found some more spiders. Send me an address by private message & I'll send them to you with the bleeder kit. George
If you have another bleed kit, I'd be interested.
1954 Chevy custom 261CID, T-5 5 Speed. 1952 Chevy 6400 2 ton hydraulic flat bed.
OP
If you have another bleed kit, I'd be interested. Sorry, I don't have any more bleeder kits. George
