The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 79 guests, and 3 robots.
Forums60
Topics129,207
Posts1,047,820
Members46,222
Most Online1,229
Jan 21st, 2020
Page 2 of 3 1 2 3
Thanks for the tip EdPruss! Will definitely keep an eye open. Ah shoot, after reading panel fan's post I remembered mine has the drive shaft handbrake, so that would definitely complicate installation.
1961 Chevy C40 Flatbed
Hi Grant , I take it your hand brake is a drum on the rear of your trans. which would complicate getting a safety if you switch to an overdrive trans.
A truly expensive option would be to locate a Gear Vendors over drive divorced unit which could be mounted in the place of your hanger bearing which come I understand with a .80 O/D .
You never know what you can find on the internet used . Good luck .
good planning is no substitute for dumb luck
Many Brownies came with Tru-Stop disc brakes on the rear. Many were disabled with the advent of Spring Brakes, however they make for a convenient and legal setup with a brake on the last gearbox. There is a place in Denver that has new pads. On my ‘54 GMC, someone had inserted a smaller disc that had worn so badly, I had to back-up to get it to release. Luckily I had saved the proper size disc in my junk.
Photo shows 5531 installation in my ‘55.2 GMC.
Ed
My Brownie has a drum e-brake with external contracting band. The brake was made up after its original installation and has the anchor for the band welded to the rear cross member. I think it dates from before spring-brakes as the brass tag says 6231A Spicer Brown-Lipe. But why the custom brake setup? It was in a GMC log truck when I got it, behind a 6-71 diesel.
51 3800 PU, 62 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Driveshaft parking brakes need to be installed on the last transmission so they work in case any of the transmissions are put in Neutral.
Mike B smile
Rustbucket Ranch
Seeing that your original rear end is an HO72, the third member can be swapped out with one from a 3/4 ton HO52 rear end for a possibly better ratio. I've read somewhere that '67-72 Chevy 3/4 tons with an auto trans have a 3.73 gear, but I bet finding one in New Zealand would be rather difficult.
A 14 bolt would be good to swap under your truck, and would be easier.
1949 Chevy 3100 (In the family since new)
1955 Chevy 3100 (Dad's truck)
1955 Chevy 6500 (Possible parts truck?)
1958 Chevy 3800 w/ 9 foot bed (Current project)
1959 Chevy Spartan 10400
More pics in my albums [get.google.com]
Unrepentant VW Lover
Hey gang -- once again I get to blow my whistle and throw a flag out onto the field ... wink
Before we get him too tall on his gearing, shouldn't we be asking about the other links in the power chain -- such as what engine, which size wheels and tires, blah blah blah?
Just asking as it seems to me that if he's got a 6-cylinder engine, he may not have enough power/torque for Brownies, tall gear sets, etc ....
In my own experience, I did the whole gear swap for faster speeds ... but ... I had a 1-ton, as well. 4.10 gear in rear and 17-inch wheels. Only I had it all powered by a 216. My truck couldn't get out of its own way, much less anyone else's. Over geared and under powered. Gotta look at the whole equation, not just one part.
headscratch
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
'49 Chevrolet 3804
'73 IH 1310 Dump
'14 Ford E-350 4x4 (Quigley)
headscratch
If it was my rig I've got a NP540 direct 5spd I'd put In it. 4.10 would be good in direct for crusing along until you hit a hill or headwind, then run in 4th.
BC
1960 Chevy C10 driver 261 T5 3.73 dana 44
1960 C60 pasture art
NP-540 series is a good choice. I put one in my early Bronco with a Buick V-6(fuel mileage) and used the top 4 gears all the time except with large load(10 thousand lbs.)
Ed
What we had on our old forklift was a pinion mounted parking brake. It was a large disc (14"??") with the caliper bracket mounted to the pinion flange bolts. Was super effective since any force applied to the rotor was multiplied by the rear end ratio, 6.67 in this case. Have seen this set up on hot rods with both mechanical or hydraulic calipers. The newest Factory Five kit cars have both a large and small park caliper on the rear discs.
Evan
Page 2 of 3 1 2 3
Moderated by  SWEET
