The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Cosmo, Drew54, 3B, Harold41, Chuck52, 1 invisible), 127 guests, and 3 robots.
Forums59
Topics128,597
Posts1,041,771
Members46,055
Most Online1,229
Jan 21st, 2020
#1449693 Wed Apr 27 2022 08:11 PM
37 GC Offline OP
fender welt. I'm assuming it was not original on trucks...does anyone use it? advantages/disadvantages?
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1449726 Thu Apr 28 2022 02:38 AM
You are correct. Welt was not used by the factory but it makes for a nice clean look on the fenders.
Harold
Harold
37 GC #1449757 Thu Apr 28 2022 12:36 PM
I am going to use it on my 66 resto. I like the looks of it. Friend of mine who paints says it will hold paint as long as it is in place first so that is what I am going to do.
I think my body panels are going to line up well, but for 50 bucks it is going to make sure it looks good.
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces.
Transmission is done! Rear Suspension is done! Wheels are done! Bed bodywork is done! Soon to order a 383 crate.
37 GC #1449771 Thu Apr 28 2022 03:30 PM
I have to chime in, when I removed the front fenders on my 1954 3604, there was this beautiful ocean green paint, and a "rubber gasket" between the fender and the cowl. I did some research and found that part number 609725 was available at Chevs of the 40"s, die cut with correct hole spacing. In the FAM , section 11, sheet 1 illustration references anti-squeak on Sheet 9.00. Sheet 9.0 shows anti-squeak ( gasket ) between fender and cowl , # 3685575. That part number was superseded to part number 609725 per the 1950 Master Parts Catalog. Below is from the Master Parts List. Hope this helps in the discussion and no, there is not anti-squeak on the rear fenders originally.
Ron
1954 Chevy 3604 - A work in progress...
Veteran, USMC
" You can't keep dancing with the Devil and wonder why you're still in Hell ! "
"Everything happens for a reason, sometimes the reason is you're stupid and make bad decisions"
Ferris Bueller #1449821 Thu Apr 28 2022 11:19 PM
37 GC Offline OP
Not sure where you would use it on a '66 unless its maybe a stepside, but it makes sense on the old open fender trucks and cars.
Larry
Dusty53 #1449823 Thu Apr 28 2022 11:28 PM
37 GC Offline OP
Ronnie, that makes sense and I have seen anti rattle gaskets for the running boards for my '37 also. what I'm referring to is welt that actually has an exposed round bead that runs between fender and body. Mine will have black fenders and I would just get black welt and use it when installing the painted fenders. I've seen it painted in place on some cars at shows and because its plastic of sorts, the paint is often cracked with time. Not a good look.
Larry
37 GC #1449846 Fri Apr 29 2022 02:35 AM
I'd think that black would work on most applications. I've seen several trucks, including red, yellow and blue paint jobs with the black and it "looked right" to me. I'm going to use that style on the rear fenders of my 54'.
Ron
Veteran, USMC
Moderated by  HandyAndy, klhansen
