The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (DaveV, 68ironhead, jameschevypu50, NorCal52Suburban, 87GN, 2 invisible), 105 guests, and 4 robots.
Forums59
Topics128,597
Posts1,041,768
Members46,055
Most Online1,229
Jan 21st, 2020
Where does the inner fender sponge seal go? 1947 second series.
I was delighted to find detailed instructions included with the inner fender gasket set. When I started installing, the tar paper gasket location was obvious. The sponge seal location has got me baffled. I cut the 20” length and it looks to be about 2” too long on the front of the inner fender. The rear of the inner fender looks completely different than the document. I checked in the FAM, but that seems to be 1954 and the same as this document.
I’m thinking about cutting some tar paper for the straight edge where the three bolts fasten to the kick panel, and using the foam for the bendy part at the top. What did you do here?
1947.2 Chevy Panel Truck 1 ton
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
If you bought a kit, there should have been gaskets / seals for the part of the inner fender that connects to the firewall. I don't see why a set made from tar paper wouldn't work just as well. I used weather strip adhesive to attach them to the inner fender. Here's a couple pic of my 1954, under hood and under the left front fender. Should provide some help with the sponge rubber, even though the 1947 - 1953 fenders are not exactly the same as a 1954 due to the parking lamp lenses....
Ron
1954 Chevy 3604 - A work in progress...
Veteran, USMC
" You can't keep dancing with the Devil and wonder why you're still in Hell ! "
"Everything happens for a reason, sometimes the reason is you're stupid and make bad decisions"
Thanks for the pictures! "Front fender skirt body seal retainer" seems to have been removed from both sides of my truck. Oh, and I think the kit did come with short strips of tar paper for the rear mounting surface.
"Front fender skirt body seal retainer" are available. I replaced the originals on my truck with Inner Fender to firewall filler panels from Classic parts of America, #37-791 . Perfect fit. As far as attaching the foam strips. I drilled 1/16 holes spaced to accommodate large staples that came in the gasket kit. PM me if needed and I can walk you through it.
Ron
Veteran, USMC
Thanks for the help, I might just get those, and I was thinking the same thing about using a tiny drill bit for the staple holes. I thought about just cutting my own, but at that price it would be a wash. I just need to order some other things so the shipping doesn't double the cost. It looks like I can proceed with the build and install those later.
Moderated by  HandyAndy, klhansen
