The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (PrestonH, john l miller), 60 guests, and 4 robots.
Forums59
Topics128,612
Posts1,041,914
Members46,061
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
The wheel in your photo IS NOT an RH-5. It's a 3 piece wheel, consisting of a barrel section with the center and the bolt holes, a full circle outer bead ring, and a split ring that locks everything together. It's perfectly safe to run "as is"- - - -there's no need to look for different wheels unless you want the convenience of running 22.5" tubeless tires. How about the front wheels? Do they have a flat raised area about 2" wide out by the barrel part of the wheel? That's the simplest way to identify the illegal and dangerous RH-5's. Because of the way the front wheel isinstalled, you'll need to look INSIDE the wheel to see that raised lip if it's the "widowmaker".
It seems that I'm just full of misinformation today- - - - -when I enlarged the pic of the rear wheel, it is indeed a RH-5 design. Those wheels will need to be changed, either to 22.5" tubeless, or the 3-piece 20" wheels I mentioned above. Sorry for leading you astray!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Here are some pics of the rear
7
Your rear axle appears to be from a 2 ton or larger, my '57 2 ton has that bolt pattern with 22.5 Budds. Fronts and rears are the same on 2 ton and larger.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
EdPruss #1449730 Thu Apr 28 2022 02:49 AM
Starting in 1956 ALL Chevrolet 2-ton and larger trucks with Budd wheels were 6-lug on 8.75" circle. After 1955-2 only the 4000 series trucks had the 5/10 lug rims. if you got the optional 2-speed 15K pound rear the lug pattern still stayed the same.
Mike B smile
You have an Eaton Rear...Chevrolet only offered them as an option on the 9000 and 10000 series 2-1/2 ton trucks.
Mike B smile
Mike B #1449748 Thu Apr 28 2022 11:37 AM
Mike B smile
What year did they change back to the 5/10 bolt pattern? All of the 67-72 medium duty trucks I have seen but one were 5/10. Only seen 1 with the 6 lug pattern and the rest were daytons.
AlexB #1449795 Thu Apr 28 2022 07:28 PM
I should have said 6000/60 series trucks had the 6-lug at least through the TF series.
I do know the 5/10 lug were used into at least the early 1970's on the 40 and some 50 series trucks (some 50 series trucks in the late 60's used the 6-lug), but the 60 series and up used the bigger bolt circle 10 lug or Daytons.
Mike B smile
GMC P-3500 used 5/10 pattern approx. ‘91 to ‘01.
Ed
I have two '59's, a 40 and a 60 series. The 40 has the 5/10 pattern and the 60 has the 6-bolt pattern.
Rich
'47 Loadmaster [stovebolt.com]
1947 Chev. Loadmaster
1959 Chev. Viking 40
Genie: "I am the genie from a magic lamp and I have the power to grant you three wishes."
Me: "I want to be rich."
Genie: "OK, Rich, what's your second wish?"
Page 2 of 2 1 2
Moderated by  69Cuda, Grigg
