The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
My 1953 235 6 cylinder has a head that has two different mounting options for the valve cover. I have attached a photo. I'm curious about tapped holes in the head to screw the valve cover on and it also has two posts for the current valve cover. I guess my question is did they use two or has this been modified?
You have a later motor, '53 was last year for the two studs on the valve cover. Be interesting to check the numbers and see what year the motor actually is. I've ran the two stud cover on several 235s up to 1962.
