Keeping your resto going
A good bit of advice nestled in the FAQ page. |
Irwin Arnstein working on his 1959 Chevy 1-Ton |
Read the article.
3 members (1950 FC253, TPR57C, 1 invisible),
80
robots. |
Key:
Admin,
Mod
Forums59
Topics128,524
Posts1,041,226
Members46,037
Most Online1,229 Jan 21st, 2020
Good thing Larry lives where wood is plentiful.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
At least he's not using cement blocks!
Mixed Up
No comment on knowing wood. But I do know my way around steel!  Don
Don Don Don,  RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1951 Farmall Super A
Retired Construction Worker
No comment on knowing wood. But I do know my way around steel!  Don It was safe ,,All I needed it up this high for was changing the pan gasket and replacing all the brake lines to the wheels with stainless ,, I worked off the rolling stool at just the right height .. I got them 2" board free at the job I was working on building a new grade school.. they just burned all the tailings up every few days ..a METAL lift would of been nice though..
Directions are just another mans Opinion
Mixed Up
Idaho, I was not knocking how safe it was. I had some other thoughts about Ron's comment about knowing wood. But, those thoughts are not fit for this forum. Yes, I fall into the gutter fairly fast.
Don
Don I didn't take it that way Don ,, I replied to everyone eplaining that it really wasnt as unsafe as it might look .,, I had a couple guys stop by my shop back then and thought it looked scary to them too.. I would maybe had a lift put in ,,but I built the tall doors so to get my back hoe in the shop when servicing it, AND if I were to be swaping out a motor I might of had on blocks the first lift ,,but not the second .. by the way ,,did you ever get the chance to climb the cooling tower,, ?
Ever seen a big piece of construction equipment like a dozer or a crawler crane being repaired onsite? A stack of railroad ties in the proper crisscross pattern will hold up an incredible amount of tonnage- - - -perfectly safely! Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
I also knew it was perfectly safe--much safer than concrete blocks--hence my comment.
Mixed Up
Idaho, that setup looks good, but would be a pain to get it there and back down. And no, I did not get to climb the cooling tower. I wanted to in my younger days, but about the age of 45, I didn't want to as much. I do have pictures I took from the top dead center of the Can looking straight down into the open reactor during a refuel, probably about 70 to 80 foot. We were doing an inspection of the containment spray nozzles. Did you get to climb the towers at Columbia? Or did you help build them?
Jerry, I have seen a lot of heavy duty cranes set up on fresh 12x12 oak cribbing. I'm talking over 100 ton cranes. Idaho has too, I'm sure.
Don
