The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Remember old days
Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to
The Wayback Machine.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (Darling, moparguy, WE b OLD, D B Cooper), 81 guests, and 3 robots.
Forums59
Topics128,108
Posts1,037,349
Members45,936
Most Online1,229
Jan 21st, 2020
Page 2 of 3 1 2 3
coilover #1448891 Thu Apr 21 2022 01:33 AM
Good thing Larry lives where wood is plentiful. grin
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
coilover #1448896 Thu Apr 21 2022 03:39 AM
At least he's not using cement blocks!
Rich
'47 Loadmaster [stovebolt.com]
1947 Chev. Loadmaster
1959 Chev. Viking 40
Genie: "I am the genie from a magic lamp and I have the power to grant you three wishes."
Me: "I want to be rich."
Genie: "OK, Rich, what's your second wish?"
coilover #1448897 Thu Apr 21 2022 04:47 AM
Mixed Up
No comment on knowing wood. But I do know my way around steel!
eeeek
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
coilover #1448902 Thu Apr 21 2022 11:50 AM
Don Don Don, dang
RonR
1970 340 Duster
1951 Farmall Super A
2-Ton #1448922 Thu Apr 21 2022 03:31 PM
I
Retired Construction Worker
eeeek
Don
It was safe ,,All I needed it up this high for was changing the pan gasket and replacing all the brake lines to the wheels with stainless ,, I worked off the rolling stool at just the right height .. I got them 2" board free at the job I was working on building a new grade school.. they just burned all the tailings up every few days ..a METAL lift would of been nice though..
Directions are just another mans Opinion
coilover #1448958 Thu Apr 21 2022 10:41 PM
Mixed Up
Idaho, I was not knocking how safe it was. I had some other thoughts about Ron's comment about knowing wood.
But, those thoughts are not fit for this forum. Yes, I fall into the gutter fairly fast.
Don
"The Flag Pole"
'50 2-ton flatbed
2-Ton #1448966 Fri Apr 22 2022 12:43 AM
I
Don
I didn't take it that way Don ,, I replied to everyone eplaining that it really wasnt as unsafe as it might look .,, I had a couple guys stop by my shop back then and thought it looked scary to them too.. I would maybe had a lift put in ,,but I built the tall doors so to get my back hoe in the shop when servicing it, AND if I were to be swaping out a motor I might of had on blocks the first lift ,,but not the second .. by the way ,,did you ever get the chance to climb the cooling tower,, ?
coilover #1448976 Fri Apr 22 2022 01:59 AM
Ever seen a big piece of construction equipment like a dozer or a crawler crane being repaired onsite? A stack of railroad ties in the proper crisscross pattern will hold up an incredible amount of tonnage- - - -perfectly safely!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
coilover #1448982 Fri Apr 22 2022 03:36 AM
I also knew it was perfectly safe--much safer than concrete blocks--hence my comment.
Rich
coilover #1448983 Fri Apr 22 2022 03:51 AM
Mixed Up
Idaho, that setup looks good, but would be a pain to get it there and back down.
And no, I did not get to climb the cooling tower. I wanted to in my younger days, but about the age of 45, I didn't want to as much.
I do have pictures I took from the top dead center of the Can looking straight down into the open reactor during a refuel, probably about 70 to 80 foot.
We were doing an inspection of the containment spray nozzles.
Did you get to climb the towers at Columbia? Or did you help build them?
Jerry, I have seen a lot of heavy duty cranes set up on fresh 12x12 oak cribbing. I'm talking over 100 ton cranes.
Idaho has too, I'm sure.
Don
"The Flag Pole"
'50 2-ton flatbed
Page 2 of 3 1 2 3
Moderated by  Justhorsenround
