The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Drew54, bolter5410, chuck2213, Flatblu4748, 87GN, cshades), 134 guests, and 3 robots.
Forums59
Topics128,597
Posts1,041,772
Members46,055
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1448489 Sun Apr 17 2022 08:45 PM
37 GC Offline OP
Hoping someone out there has a picture or can do a drawing of the engine side of the firewall with all the cables and wire locations per original placement labled. Stock, Original is what I'm looking for. Just bought all the grommets and getting close to needing that info for prelim placement. Luckily I dont think there are a bunch of extra holes to fill, but would like to do that if needed before paint prep.
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1448510 Sun Apr 17 2022 10:37 PM
37 GC Offline OP
couldn't decide where this might belong so thanks for the decision! lol
Larry
37 GC #1448517 Sun Apr 17 2022 11:13 PM
Ex Hall Monitor
I don't know how or if it translates to the truck but I have pictures of my 38 car on the other computer. I'll have to post tomorrow since that computer is off for the rest of the day.
Let's go Jared!
37 GC #1448533 Mon Apr 18 2022 12:40 AM
Curmudgeon
Hope this helps.
37 GC #1448582 Mon Apr 18 2022 03:16 PM
37 GC Offline OP
yes this helps a bunch, but a couple of missing things. Speedometer cable and electric to headlights and horn and also how they are routed along the fender. The heavy shielded wire to the coil is original design? my shop manual doesn't show any pic of that, are the terminals there? I know my six v coil was mounted wrong (upside down) but the terminals were on either side of the center coil, distributer wire like the 12v I will be using...so what's up with the coil?
Larry
37 GC #1448588 Mon Apr 18 2022 04:51 PM
Ex Hall Monitor
The armored cable is called an electrolock. The correct coil will have a terminal under the cap that the ignition switch connects to. It was a method of preventing hot wiring the car. Let me see if I have a picture showing where the speedo cable penetrates the firewall.
Edit: I have a picture but not one good enough to do any good. The speedo cable and wiring to the front end pass through a grommet to the outside of the steering mast. Hopefully someone will have a good photo.
Edit2: I found one that shows it. Posted below.
Let's go Jared!
37 GC #1448619 Mon Apr 18 2022 10:22 PM
Curmudgeon
Determining what is original is not an easy job. Just because it sells high dollar at Barrett-Jackson doesn't means it's truly 100%.
Just now found this link at Jim Carters'. Horn conduit..."get out of town", I didn't know that.
https://oldchevytrucks.com/blog/2020/01/1934-1937-chevrolet-horn-wire-conduit/
The electrical for the headlights would be from the dimmer switch on the floorboard.
The supply for the switch may follow the speedometer cable. I haven't found a picture yet.
Tiny #1448661 Tue Apr 19 2022 04:29 AM
37 GC Offline OP
Tiny, thanks for the explanation of the electrolock. The pic must be a sedan. the floorboard, toeboard and firewall penetrations are totally different.
Larry
37 GC #1448662 Tue Apr 19 2022 04:47 AM
37 GC Offline OP
to heck with Barrett-Jackson but I would put stock in the VCCA type opinions. I will not be at that level as I'm going 12v, plastic insulation wiring harness, fusebox with headlight relays and turn signal flasher, double tail lights, but would like to reuse the proper locations as much as possible. I did see the horn conduit while browsing Jim Carter before and my horn mount bolt did have the clip but no conduit.
Larry
37 GC #1448677 Tue Apr 19 2022 11:31 AM
Ex Hall Monitor
Mine is a coupe. That's why I always preface with the statement that I don't know if what mine has will translate to a truck. Good luck with your project.
Let's go Jared!
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
