The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
5 members (WE b OLD, Slick Willy, DRCA, coilover, 1 invisible), 89 guests, and 3 robots.
Forums60
Topics127,667
Posts1,046,494
Members46,401
Most Online1,229
Jan 21st, 2020
Page 3 of 7 1 2 3 4 5 6 7
Great advise. Thanks!!!
I do find it quite discerning that the repair panels made in China and Taiwan don`t
fit properly. That/they probably should not be imported. IDK what else to do with the truck but if I am fighting an
uphill battle, thats difficult with my expertise level.
If all this fails, I guess my alternative would be to turn it into a fleet/step side?
Hopefully the frame is not much different than either of those. Would just need a cab.
1958 3100 Apache 327 engine
1958 3100 Apache Panel 1/2 ton 235 engine
1959 3100 Apache Panel 1/2 ton 327 engine
The patch panels from offshore can definitely be problematic, but they're just metal. You can make them fit with some massaging. Front clip parts may be another issue, but everything can be fixed, given enough time and patience. I think you're cab floor can be successfully repaired. You just have to be sure the dimensions are right. It would be a shame to just replace the body with a pickup cab/bed. Everyone has one of those. Hang in there. You'll be an expert when you're finished.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Hey thanks man! Great news. I guess. I raised the floor where
I thought it should go and placed the lower rear pillar patch panels and
both fit perfect. One thing concerns me is the cross sill originally
had a body frame mount bolt there. The new floor does not look that heavy duty of a sill.
I do have something in mind though.
Looks good so far, but there's fitting and fitting perfectly. Before you commit with welding anything, MEASURE, MEASURE, AND MEASURE AGAIN.
On the body mount hole, there may be a reinforcement piece available. Definitely look into that. Do you still have the original floor to compare?
I do have the original. What I have will work. Its a cut down cross sill
50 inches. I can mount it behind the back of the new floor. And use
one of or drill a new hole there for the skid strips. I can tie that in with the new floor.
The doors look good. My plan current is to tack weld the doors to the
top of frame door and back of opening , after floor is in place ...somewhat.
I wont commit to it till after the doors are in. But so far is looks good.
Even whats left of the hump over the transmission at the front of the truck,lines up
with the new floor. But the left driver side front pillar I can visual see is off. the right side
looks true and straight.
lucky to find this rear cross sill for the very back. Mine was way shot.
I will install it and cross sills ,paint underneath and be ready soon to set on a
readied frame.
These had to be cut out. Careful not to cut thru the cross sill underneath.
Looks like you've thought it out. thumbs_up
AD Addict
Looks like it’s starting to come together. Nice work and good plan!
Phil
Moderator, The Engine Shop & Interiors
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Between the wood and the angle strip there was some black "caulk" to
act as a sealant? What is a good substitute for this?
I found an extra leaf spring bushing that fits in the cross sill body mount hole perfect.
Moderated by  HandyAndy
