What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
4 members (TrknGMC, Pat66, 2 invisible),
89
robots. |
Key:
Admin,
Mod
Forums59
Topics128,612
Posts1,041,915
Members46,061
Most Online1,229 Jan 21st, 2020
OP
Retired Construction Worker
I forgot to push it in my 54 this week and after a few miles it was running rough and it did not help that I left the electric fuel pump on. At least you did remember it after only a bit... Good going My older brother borrowed my 65 and before he left with it I told hm how to use the choke.. he forgot and bent my choke wire and when he brought it back he said to me Boy ! your truck for being new sure runs terrible .but,,that he fixed the problem ,, he had a guy set the carb so it would run better ,,that was the only time I ever got mad at my brother.. tonite I got a guy from this forum coming to my house to look the situation over .. nice forum ,with nice people in this forum..
Directions are just another mans Opinion
OP
Up date on my emissions failing .. first of all I want to share with you about what a great young man we have here on the forum.. he drove over here to my place across town and fixed my choke wire that some one before me had used the whole (nine yards as to say) and had it curled up under the dash and run through the fire wall at also a bad angle ..therefore to long and crooked for the hard wire in the flex casing to be able to move the carburtor butterfly shut or closed. He shortened it and it works fine now ..
He took down my carburator number before he left and will be coming back neext week to do some changes with the slow idle that will make the truck pass emissions when I go back again,,,by the way he has a real cool old truck too that he got from his grandmother .. he put a new Chevy 2000 motor in it and it looks real good in there.
His name on this forum is Fibonachu ,,I am glad to have such a nice guy close by in town here that just loves working on old cars and trucks,,,,,,,,,,, I thank you Jason
OP
Update ,.Fibonachu came today and reset my carburator,,,he tuned it to a leaner mix and now the choke works for a cold start and it's now a turn key and it starts right up.. Next Monday is show time at the emissions testing place
I actually richened it up. It was running so lean at idle that it wasn't consistently combusting. We threw my wideband on it and found that it was flickering between 17 and open air. When we richened it up, the idle smoothed out, we picked up quite a bit more vacuum, and got the AFR down to about 14.2. That leaves it a hair richer than stoich, but I prefer to be slightly on the rich side.
I generally recommend not counting chickens and all that, but I am pretty confident it will pass just fine now.
It is a real nice rig. I look forward to seeing it on the road more. By the way, Idaho39 has great pie. Thanks again!
58 Apache, long bed fleetside, V8 w/SM420 Drivable but the rear axle needs work.
here in Washington you only had to test in a few heavily populated counties. After a couple of dozen years, the state realized that only a tiny fraction of cars were failing, and the ones that did were so few that environmental problems were miniscule So they dropped the requirement.
"Happiness equals reality minus expectations" - Tom Magliozzi
OP
I have had good luck with Quadrajet Carburetors in my past Chevy Trucks ,,but as of late been convinced that a Edelbrock is the one to go to ,,to pass the Idaho emission test.. I will share with you the outcome after the install of the Edelbrock Carb by Fibonachu who is guiding me in the right direction about the Carburetor problems I have been having.
A brand new Edelbrock makes a good paperweight. It's a pretty poor quality "clone" of a Carter AFB, and it's definitely a giant leap backwards from a Q-Jet. One that's been run tends to stink up the paper, though! Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
OP
Jerry ..why do you say that,, ,, your one of my go to guy .. ..when I read this .......... Edelbrock #1406 600 CFM Performer 4 Barrel Carburetor Best Edelbrock carburetors for Chevy 350
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
I suspect it has a lot to do with where the Edelbrock carburetor and internal parts are manufactured. They are not the quality they use to be. Some people have great results with them and some (me included) have nothing but trouble. If you are a good carburetor tuner you can make the necessary changes to make them run like a scalded cat. For some the Holley is just as bad. I’m currently running a Holley on my 450hp 350 in the ‘62 C-10. Starts easy and runs very strong. Fuel mileage sucks. When I get the time I’m going to go through my stash of Quadrajet carbs and build one up to replace the Holley as an experiment. Good luck
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
