A wonderful difference!!! No more junky truck front end sounds. Rides smooth on the bumpiest of roads!! Very important around here. Sits up stronger looking. Like my 58 A must if you have original leaf springs that are worn or collapsed. That s 7 leafs in a short time. Note my 58 3100 is minus those angle plates for the spring /axle. Has handled and continues to handle incredible. I could not imagine it being any better after new springs and no plate(s).
BD
1958 3100 Apache Step side 1/2 ton 327 engine 1958 3100 Apache Panel 1/2 ton 235 engine 1959 3100 Apache Panel 1/2 ton 327 engine In Project Journals
Thanks Wi Crusier!!! Couple other things. I will be getting a thermal sleeve for the fuel rubber line. Maybe a thermal shield between carb and manifold. power steering after I get the black 58 s engine back in and the M-22 mounted. I have to cut the hole in floorboard and carpet to fit. I did remove the borg warner 3 speed OD and will sell it.
BD
For those who might seek a bed mat for these. This one for a 96 inch bed 2007-2018 Chevy Silverado/GMC Sierra 8 Feet (96") fits with little cutting. Just the end behind the seat. Just missing 3 inches on the side
BD
