Oh Lord, I just gotta find it....
Forums59
Topics128,081
Posts1,037,108
Members45,928
Most Online1,229 Jan 21st, 2020
OP
I have a portable generator with a dirty 5 gal. gas tank. Someone left gas in it and it is nasty, So what is the best way to clean it? I was thinking some laquer thinner, or maybe some dawn dish washing soap and a lot of water? Any ideas would be helpful.
Tommy 59 apache 1/2t 261 short stepside
I don't know what you'll wind up doing, but I had a log splitter like that and ended up having to take the tank off, split it at the seam and paint the inside of it with JB-Weld diluted with acetone enough that I could paint a couple of coats on with a cheap bristle brush. 4 years later it is still fine, but there was no way to dissolve that stuff. I tried everything including toluol, xylol and some other solvents most people haven't even heard of. Good luck!
Jon
1952 1/2 ton with 1959 235 T5 with 3.07 rear end
E85 works very well to dissolve varnished gas or diesel. I use it regularly for carb cleaning and last time was on my 47 3600 under bed tank that had a black sicky goo from forty years of sitting.
OP
Don't want to sound stupid, but what is E85?
85% Ethanol you buy at the gas station.
It is a fuel that is 85% ethanol. You can get it at some gas stations.
Are you familiar with "flex fuel" vehicles? They are ones that can run normal gasoline or E85.
58 Apache, long bed fleetside, V8 w/SM420 Drivable but the rear axle needs work.
I put a shovel full of gravel into a dirty tank, strap it to the rear wheel of a tractor, and bush hog one of my pastures for a couple of hours. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
I removed a heavy layer of tar from the tank on my Model A with a gallon of lacquer thinner. Then had to deal with all the rust flakes inside it that were stuck to the tar. Just about any solvent should eventually dissolve the tar-like gasoline residue.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
OP
It's a plastic tank, (something other than metal). Guess I'll try the lacquer thinner and slosh it around for a week or so.
