What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Forums59
Topics128,613
Posts1,041,924
Members46,061
Most Online1,229 Jan 21st, 2020
OP
replacing the brake master cylinder on my truck and having problems removing the pedal arm of the master cylinder I have removed the bolt on retainer clip but not having any luck removing the pin is there a speciel procedure for this?
Moderated
on my 59 c60 I just had to use a punch and hammer to gently get it started
1959 C60 viking grain bed
OP
yea thats what I did was get the MC out and give it a tap or 2 to get it to move
