The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
I’ve seen it recommended to use your 216 thermostat housing on a 235 swap. Seems the upper hose may require use of it. I put the 235 housing next to the one on my 216 and can’t tell any difference. Do I have to swap them out?
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod
