The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Chris's 46 / 515, crenwelge, 55_2nd_Series, Jethro in Va, 59 fleet, FAST55), 118 guests, and 3 robots.
Forums59
Topics128,581
Posts1,041,644
Members46,050
Most Online1,229
Jan 21st, 2020
Page 10 of 14 1 2 8 9 10 11 12 13 14
Last couple of update photos
Originally Posted by TUTS 59
I think you need to change the name on this thread, this is definitely not a "Low skill, low buck build. Really coming together, very nice work.
Thanks man, I'm doing my best... but there are some truly beautiful trucks on this site that make my attempt seam pretty low rent
This is looking so good! I'm currently fitting the radiator for my 1940 too and I'm having serious concerns about what the previous owner did. The upper grille doesn't seem to match up so either the upper grill is warped or the front panels are. Would you mind tossing me a measurement for the 2 bolt holes at the front of the grill?
I think I got the spot you were looking for… came out at 17 1/4 inches from head to head
Worked on the passenger side windlace …kind of a pain to deal with.
Ordered some mix and match jewelry for the truck that I'm hoping to get mounted this week. The math says they should fit but it's going to be tight and/or might require some minor modification to the bed side.
Crusty Old Sarge
That's a lot of tire for your wheel well, it will look nasty if you can get them under the truck. thumbs_up
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
Got my tires/rims mounted... Happy with the look and it will make a nice change to switch them out with the steelies every now and then.
Also figured out that my shiny new alternator wouldn't clear the top frame rail due to it's body size...so out goes the power master and in goes the alternator from an 85 samurai...not that it matters since it's mounted low and out of sight...still sigh
So… I got the alternator mounted and it looks like I may have to re-think the current configuration. Slight pulley alignment and possibly limited adjustment… but on the plus side.. it now clears the frame rail.
The trucks original trans crossmember was cut in the middle to make way for the TH400 so the plan is to have a removable support brace to take the load behind the leaf springs. Using what's left of the original drop brackets as the base.
Moderated by  HandyAndy
