Holidays are over
Hunkering down for winter ... how about your truck?
Forums59
Topics128,267
Posts1,053,228
Members46,580
Most Online1,229 Jan 21st, 2020
Last tire I had fixed was $25.00. It was one of the new low profile tires.
I generally fix my own flats, which are rare. Usually just a small nail hole. But $20. for a repair job isn't something I would complain about.
Recently an elderly fellow from out of state hit a pot hole and burst the inside wall. He had finally stopped right in front of my house and came knocking on my door. It was a Honda with low profile tire so I had him pull it to the shop door. While jacking the car up he informed me the car came with NO spare tire what so ever. Not even a donut......its Saturday so off to wally world we go. He found a tire and when asked about getting it mounted, as I had his old one in the back of my truck, the shop foreman hollered and ask the "tire guy" if he would mount a new tire. The EMPL:OYEE yells back yeah, in about 3 1/2 hours. I explained the situation an how it'd 10 minutes and I could get the old man on his way. He made us stand there for 40 minutes while he wrote down oil changes "3 cars back". We were stuck. All my tire guys are closed on Saturday. So I told him it was the first time I ever seen an employee tell the foreman how to run his job!! Then I ask how much and how long it'd be....$18.50 to mount/balance and he made the guy come pick the tire up at 5pm closing time. In my area 90% of the folks will mount and balance it free if you buy a new tire.
Now, like Jerry, I changed many tires back in the day, tube type, for the station "special" of $1 and with the old manual set up where you broke it down physcially. Another place here in town will not plug a tire and changes $25 to patch it no the inside. He is not a nice guy anyway so nothign lost there. I've plugged many tractor trailer tires (ran new tires on steering axle) and never had a problem. The strips are longer for the bigger tires.
For myself, I USED to plug my own but after all the surgeries I no longer have the upper body strength to plug one but my neighbor does!!! My LOCAL tire guy pulls the nail out and plugs 95% of tires on the vehicle and I'm gone in 5 minutes usually with no charge. Whats this world coming to..........oh, I know, I'm not in Kansas anymore Toto.
ok ok, ,I'm through.
Drafted Moderator!
I carry a plug kit and a 12 volt air compressor in our tow vehicle. Plugged many tires on the truck and trailers over the years, by the side of the road. We have a a 2011 Subaru Forester and if a tire goes bad, either fix it or buy a new set. It does do really well in snow though, with the all wheel drive computers system. As a disclaimer, it’s the wife’s car.
Don
About a month ago I had a flat on my Equinox. Took the tire and wheel off, and took it to the local Firestone dealer, said he was booked and couldn't get to it for two and a half weeks. End up dropping it off at Walmart, and picking it up a couple of hours later.
Brian 1955.2 3100 Truck
Were you being charged by the hour, or is $20 their flat rate for fixing a tire? If it had taken 20 minutes instead of 12 would the price have been the same, or twice as much?
In about 1960, I fixed flats where I worked at a service station. Emphasis on "service." Pulled out the nail and patched the tube. When they started plugging tubeless tires, I wasn't working there thank goodness.
1948 3/4-Ton 5-Window Flatbed Chevrolet [ sandeace.com] 29 Years of Daily Driving. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
When steel belted tubeless tires came along, the only effective repair method was a patch for the inner liner, and a plug that sealed the belt from contamination by water, mud, salt etc. I started installing "patch plugs" with a rubber stud built into the center of the patch in the late 1970's, and that's the only kind of tire repair I'm willing to bet my life on, regardless of the cost. I don't intend to be a dead cheapskate! Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
OP
Grease Monkey, Moderator General Truck Talk & Greasy Spoon and HiPo Forum
Jerry, can you still buy those?
Rich, $20 flat rate unless required more than one patch. I’ve used the guy for years and he’s good at what he does. It’s been about 5-6 years since I had one fixed and I paid $6 for that one. Inflation
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
